Question about Garden
For lawn mower champion J19LM what is the gap
  • 12650 Answers
SOURCE: I have a lawn mower that needs a spark plug. I
reason for different plugs are because motors require different lengths ,temperature,design etc-it may run now but if its to long-or short can cause engine problem or damage-same for hot or cold can burn valves-or carbon up valves or plug -change it to the recommended plug mower will last longer with correct replacement parts
Posted on Mar 13, 2010
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
rjpoirier_nb
  • 166 Answers
SOURCE: lawn mower has too much oil. how do I drain excess
Remove the small plastic oil filler plug where you put the oil in, and turn the lawnmower onto it's side to drain any or all of the oil.
Posted on Jun 13, 2010
  • 100 Answers
SOURCE: what is the gap on 4.5 hp Briggs and Stratton
.5mm but all plugs come pre gapped from factory...
Posted on Aug 14, 2010
GBELECT
  • 23 Answers
SOURCE: Can I download an instruction manual for the
go to this free manual site,no crappy ads just asks for 1 answer when you download a manual. it is a great resource
http://www.manualsonline.com/
Posted on Sep 12, 2010
Briggs stratton repair manuals
briggs uses a champion j19lm plug or NGK b4 plug with a gap of.028
Jul 31, 2014 | Garden
Spark plug for southland mower model 38-9222
champion j19lm or champion rj19lm. either should work
Jul 25, 2012 | Garden
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
I have an old Craftsman lawn mower and just need to verify that I have the correct spark plug and what the gap should be.
You have not given any specs on what engine you have (Briggs? Tecumseh? Craftsman uses both on their machines), but most of the ones I fix use the same old standard Briggs spark plug, which is a Champion J19LM plug gapped at .030. (The Champion is not required, just the most common and you can cross-reference it to other brands. If you provide your engine make and model, then I can tell you exactly what to use.
James
Aug 10, 2011 | Garden
I am replacing the spark plug on a 5 hp Quantum engine that is on a Troy Bilt walk behind mower. I would like to know the spark plug gap setting on that motor.
I'm guessing you have a standard Champion J19LM plug, which has a gap of .030. They come pre-gapped from the mfg. and usually no need to adjust them. Most of the plugs on these engines have a .030 gap. There are very few exceptions that use a .020 gap (such as the RC12YC). Anyway, here's a link to a chart I like to use for reference: (there's a drop down menu at the top to change engines, but the standard Briggs engine is the one here).
http://www.manddsmallengine.com/briggs/info/plug7.html
Hope this helps. James
Aug 06, 2011 | Briggs & Stratton Garden
What is the gap setting on a spark plug j19lm for a craftman lawn mower
The spark plug gap for this and the majority of mowers is 0.030 gap. H/ope this helps.
May 19, 2010 | Baby Care
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
