Question about Lexmark Prestige Pro 805 Color All-in-One Wireless InkJet Printer
Wireless wifi not connected
  • Official Brand Answer
  • 3,344 Answers
Your wifi connection problem could be due to firewall, wireless signal quality or wireless signal interference. Here's an article from the Lexmark website that will help you identify and fix the wireless connection problem:- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Posted on Feb 14, 2012
NAD WIRELESS USB DAC 1 KILLS WIFI CONNECTION
The NAD wireless using the 2.4Ghz frequency which is also used for WIFI.
Your option would be to change the channel of your WIFI to see if you can reduce the interference.
Your best option is to use 5Ghz for your WIFI (this requires that your Wireless router and Laptop support 5Ghz).
Jan 31, 2014 | NAD DAC 1 Wireless USB digital-to-analog...
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    I can't figure out how to connect to the internet with my Belkin card.
    this is wireless (wifi) receiver
    the first you need is wifi connection around your computer
    if there any wifi connection aroud you, at your computer open and search the available wifi connection, then chose connect
    and you can connect internet after you connect your belkin to wireless connection
    Mar 25, 2011 | Belkin (F5D7011) 802.11g/b Wireless...
    I have a WIFI and I heard that I can connect my HP OFFICEJET 5610 ALL IN ONE into wireless using my WIFI connection. Please assist me. Thanks a lot, Toha ****
    hi tohafaniwang
    the HP OFFICEJET 5610 doesn't have an internal wireless adaptor therefore you would not be able to connect it wirelessly to your wifi network. Although there is an option to get a wireless LAN routher/printserver wherein you would connect the printer to the wifi print server/router using the usb 2.0 cable. using this you would be able to setup that all that connects to your wifi network would be able to print to your printer.
    Hope this helps
    janc30
    Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
    I dont know to use wifi in LENOVO 3000 Y410
    Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    1. Purchase a wireless router that fits your needs and price range.
    Aug 01, 2010 | Computers & Internet
    Not able to connect wifi in my lapopo
    In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
    Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
    Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
    To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
    Feb 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
    Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
    If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
    Sep 29, 2009 | NetGear DGN2000-100NAS Router
    Boost PCMCIA Wifi Card Range
    em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
    Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
    Lexmark Prestige Pro 805 Color All-in-One Wireless InkJet Printer Logo
    141 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
