Question about Freezers
DEEPFREEZER THE FOOD IN MY DEEP FREEZER STARTED THAWING OUT I UNPLUGGED MY DEEPFREEZER FOR 2-4 MIN.WHEN I PLUGGED IT BACK IN I HEARD THE COMPRESSOR RUN FOR 5-10 SECONDS THEN I HEARD IT CLICK OFF. I ALSO NOTICED THE COMPRESSOR WAS HOT. WHAT COULD BE MY PROBLEM AND WHAT DO I NEED TO CHECK?
    Champion:
  • 242 Answers
The best you can do is ensure that the compressor area and fins are not clogged by dust and such. But don't mess around long, call a repair man to fix your freezer if cleaning doesn't help. Prob cheaper than replacing your spoiled food.
Posted on Oct 24, 2008
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Mar 26, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to disable deep freeze? plz give me solution.
If there are two compressors on your unit, disconnect the freezer compressor. If only one compressor, nothing can be done as the fridge and freezer piping are in series. Assuming you have an upright fridge.
Oct 23, 2009 | Amana 15.6 cu. ft. Upright Freezer...
Homemaker chest freezer is hilling but not freezing. HAve tried defrosting and compressor sounds fine?
Try thawing out the freezer....Put all your food in a cooler, unplug the freezer and leave the door open, let the freezer sit for a few hours then plug it back in, if this doesnt help you may need to recharge your refrigerant....If you have a model you can refill hope this helps
Oct 01, 2009 | Freezers
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Condenser runs continuousley and is very hot
Don't know what kinda freezer this is? Commercial? Look for dirty condenser coils/ fins. Be sure air can circulate around condenser. Possibly low on refrigerant (freon). Need more info for more detail solutions.
Nov 15, 2008 | Freezers
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
203 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
