Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Canon ip4970 waste tank reset - Canon PIXMA iP4600 Color InkJet Photo Printer
    Problem Solver:
  • 7 Answers
This is how to do it use xp
http://www.mediafire.com/?dbi16o3ovel1iyk
download the v3400 for free in link above it is 9,5mb ( there is a other file dont use it only the service mode tool v3400 )
follow this instructions and you will be fine
http://www.2manuals.com/product_info.php?products_id=1445
- power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
4. Run the Servicetools V3400.exe program.
5. Select the connected USB port number from USB PORT
6. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
7. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM
Posted on Mar 14, 2013
SOURCE: canon multipass f80 waste ink tank
First off to do it will take you about an hour, cost you between 10 to 30 dollars. The best alternative is either take it to a Canon Dealer and pay 40.00 and don't worry if you break the seal, or I will tell you how to reset it so that it thinks it has no ink. DO NOT PLAY WITH THE OTHER SETTINGS OR YOUR PRINTER MAY NOT WORK AFTERWARDS.
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Posted on Jan 18, 2008
  • 1550 Answers
SOURCE: Reset Waste INk Canon MX318
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 16, 2008
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
  • 3 Answers
SOURCE: waste ink absorber is full. How can i fix it?
error code E7 for canon210
Posted on Jun 03, 2008
SOURCE: canon i900d wast ink tank - how to reset it ?
The following procedure is from the Canon i900D Maintenance Manual:
1. With the printer power turned off, while pressing the Resume button, press and hold the Power button. (Do not release the buttons. Wait for the LED to light green, which means you can select a function.)
2. While holding the Power button, release the Resume button. (Do not release the Power button.)
3. While holding the Power button, press the Resume 2 times. On the first press, the LED lights orange; on the second press, it turns green. Release the Power and Resume buttons.
4. The LED light should be green. Press the Resume button four times. Each time you press the Resume button, the LED lights first orange and then green.
5. The LED light should be green and the printer should now reset the waste ink counter. When the operation completes, the printer returns to the menu selection mode automatically.
Posted on Feb 14, 2009
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
Jul 31, 2010 | Acer Office Equipment & Supplies
Waste ink tank reset
Google is your best bet for a question like that, where did you get the instructions to reset the waste ink absorber?
Look there also
Jul 18, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Affichage WASTE INK NEAR FULL, where is the waste ink ?
The waste ink tank is inside the printer. You cannot do anything about it except reset the ink level count.
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
May 10, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Reset Ink Tank for Canon IPF 610
How do you reset the waste ink tank on the IPF700? Would appreciate it if someone could help me.
Thanks
Nov 10, 2008 | Canon imagePROGRAF iPF8000 Printer
Error Message
Contact Canon support ot refer to
www.fixyourownprinter,com
type your printer make model in the field.
Jan 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink tank full
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
3,548 people viewed this question
old marine
old marine
