Manual for Ruud UBHK-25J11SUZ - Heating & Cooling
2 Suggested Answers
james3751
  • 614 Answers
SOURCE: Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Posted on Jul 14, 2009
I need a Ruud 80 plus gas furnace manual
Request the manual directly from Ruud.
Mar 25, 2017 | Ruud Heating & Cooling
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
I am requesting an owners manual for My recently installed Ruud Air Handler unit Model # RHPN-HM3624JC Thank You
The right path for getting this manual is from the installers as it is a requirement by law for this to be left with the home owner. Is it a new unit ? If not then there is a couple sources for manuals. Such as calling RUUD customer support. contact info at at www.ruud.com
Aug 18, 2010 | Ruud Heating & Cooling
We need an owners manual.
Hi, looks like you have a 21/2 ton Ruud split system by the numbers. Let me look this up and see if I can find a manual for this unit and send you a link to down load it. Give me sometime please. Be back soon.
Shastalaker7
May 08, 2010 | Ruud UAKA030 Air Conditioner
Looking for a manual for RUUD model number 92212650402
Hi, you can get a manual from your local Ruud, Rheem wholesale parts house. If not, go online and you should be able to down load one. Just have the model, serial, and product number if there is one handy.
Good Luck, Shastalaker7
Nov 03, 2009 | Ruud UBHC Air Conditioner
Air Handler leaking
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ouside unit not coming on
You are not getting the 24 volt control circuit to coil need to make sure your 2 wire is in good shape and connected to the coil connections. If you have a ohm meter you can ohm out the coil and see if it is good. Be carefull cause the is 240 volts at the same spot on the contactor. So just pull the fuses out of the disconnect box and will be okay. Or turn off the breaker inside the house to the unit. If coil is bad just replace the contactor.
Apr 05, 2009 | Ruud UBHC Air Conditioner
Need to locate a Ruud Manual
You probably can call 502-456-4050 or go to site information@ruddequipment.com thank you and good luck J
Dec 19, 2008 | Ruud Central System Air Conditioner
Rudd model ubhk-24jinfg
Check your filters inside the furnace, replace if needed. Then check to ensure that the fan is running inside the furnace. If these two things dont fix the problems, I would imagine you have low refrigerant issues. In that case you should call a service company.
Hope this helps ya please rate me.
Jun 20, 2008 | Ruud Central System Air Conditioner
Blower motor
Hill, which blower motor? The exhaust inducer or the room air blower? If you are referring to the exhaust blower, check for a restriction in either the fresh air inlet, exhaust pipe or condensate line. If you are referring to the room air blower and you already replaced the motor, it is most likely a relay on the control board. You will need to replace the whole board. More info is always better!
Apr 11, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
