Question about D-Link DPH-50U IP Phone
DPH-50U default audio
I HAVE INSTALLED THE LATEST DRIVER (VER. 1.1) I CAN SEE THE GREEN PHONE ICON ON XP TASK BAR, I CAN EVEN SEE THAT THE DPH-50U HAS ACCESS TO THE SKYPE PROGRAM ON THE API ACCESS CONTROL WINDOW. BUT I CAN'T SEE THE DEVICE ON THE AUDIO SETTINGS, I CAN ONLY SEE THE WINDOWS DEFAULT AUDIO DEVICE EVEN THOUGH THE DPH-50U SAYS ITS CONNECTED.
ANY ADVISE WILL BE GREATLY APPRECIATED!!!
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Posted on May 01, 2009
Device audio not working
Try installing the latest audio driver.
You can download the drivers for your model Gateway laptopfrom this WEB site. Make sure you select your model laptop and the correctWindows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Mar 31, 2011 | Gateway M-7351u Notebook
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
I have installed Skype 3.8 and d-link driver 1.01 on Windows xp. I can select the device from the audio setting but receive no dial tone. Please assist!
In your VoIP monitor settings there are two options to make your phone connect to voip. You either have to dail # # or # *. I would try hitting pound twice, but it's kind of tricky because sometimes when the dlink tries to connect it will flip back and forth between voip and pstn. So I recommend holding the phone to your ear and hitting # until you hear that dial tone!
Jul 01, 2010 | D-Link DPH-50U IP Phone
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
DPH-50U can't be uninstalled or reinstalled correctly
To solve a problem "device not present", you must delete registry key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{55280429-413e-460f-a31a-e19314823119}\0001" and restart service "VService".
Dec 14, 2008 | D-Link DPH-50U IP Phone
DPH-50U driver using high DPCs
I had a similar problem on a pc i built. the culprit was my wireless card. i opened up the pc and moved the card from one pci slot to another. powered it on and it redetected mt card. my cpu usage went from 40-50% at idle to 0-5% depending. hope that helps
Oct 25, 2008 | D-Link DPH-50U IP Phone
How to do voip calls with the regular phone
Did you read the manual?
first you press ##
then you will hear a weird buzz
then you dial 00 and then the phone number including the country code (example in canada.. you will do 00 1 450 419 0000
then you press *
so again,
## (weird buzz) 00 1 450 419 0000 *
and wait few seconds
Nov 15, 2007 | D-Link DPH-50U IP Phone
D-Link DPH-50U IP Phone Logo
385 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
