Question about Sony SLV-N750 VHS/S-VHS playback VCR
Remote operation ( remote will not activate vcr )
Remote will not operate my vcr. Installed new batteries. tv is on proper channel. vcr will operate using face controls, but will do nothing when i try to use remote.
HELP
Bryce Petersen
brycep96@yahoo.com
801-943-3495
  • brycep96 Oct 26, 2008
    Shirldv:
    Thank you very much for trying. I had already tried these things, including fresh measured (1.6 volts )
    batteries. Nothing!! However, Thank you so much for tryin and returning your message.
    Bryce Petersen
  • nipu56 Nov 20, 2008
    The remote control does not work. All operations have to done manually
Sounds dumb, but had the same problem. I removed the batteries and double-checked that I had placed them in their respective slots correctly. If in doubt, use a completely NEW set of bats. Use the best bats you can afford. Also make sure you are pointing/aiming at the VCR sensor straight on; possibly the front of your VCR case is dusty/dirty? Just lightly dust off. No detergents. Good luck.
Posted on Oct 26, 2008
Need to program channels but don't have remote and TV VCR combo has no menu button
You can buy a universal remote from an electronics store that can operate your TV -VCR.
Just check when you buy on the brands the new remote will work with. This information is usually mentioned on the packaging.
Jan 08, 2016 | Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
LG 42PX4MVH remote control does not operate the TV, it seems that it needs to be re-synchronised, how do I do it? The batteries was replaced yesterday and the lights on the remote control flashes and...
Hello
If you are using its original remote control handset with this set, replacing batteries will poise no problem at all. If remote control does not works properly check the following.
Check to see if there is any object between the TV and the remote control
causing obstruction.
Are batteries installed with correct polarity (+ to +, - to -)?
Correct remote operating mode set: TV, VCR etc.?
The light at its side
Illuminates the remote control
buttons of selected mode.
OK.
Apr 26, 2011 | LG 42PX5D 42 in. Plasma HDTV
Won't change channels. Batteries are fine.
The remote does not operate your component?
  • You must put the remote in the correct mode by pressing the corresponding component key (TV, VCR•DVD, SAT·CBL) so the remote knows which
    component you want to operate.
  • Remove any obstacles between the remote and the component. Make sure to aim the remote at the IR sensor on the component.
  • Make sure the batteries are fresh and are properly installed. (See Battery Installation on page 3 of the User Manual). Replace the batteries with two new AAA batteries, if necessary. Reprogramming may be required.
  • Reset the remote. Remove the batteries, then press and hold the number 1 key on the remote for several seconds to reset the microprocessor inside the remote. Release the number 1 key, reinstall the batteries, and press the ON·OFF key. If the LED indicator light turns on, reprogram the remote and try again. If it doesn't light up, replace the batteries with new ones.
This and other details can find in the troubleshooting-the-rca-rcr350-universal-remote-control
I hope this help to solve it (remember to rate this answer) Good luck,
Oct 02, 2010 | RCA RCR350 Remote Control
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
I have this RCA remote and I misplaced the guidebook.
You must first find out why the remote control is not working properly. These remote controls have been having problems with new batteries. The battery holder on the positive side need to be adjusted out to make sure its making contact with the batteries. This may be the reason the remote control is not working. After you find the problem with the functioning of the remote control you can go to the RCA customer support website http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 find the codes for the components you want to use with the remote control. Use the codes to make the remote operational . This should be all you have to, if the remote control is working properly. If you cannot get the remote control to work properly, you can call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of the remote control and ask them for assistance with the problem. I hope this information help you with the problem you are having with your remote control. Thank you for using FixYa and have a nice day!
Apr 07, 2009 | RCA DIRECTV Satellite Remote Control
Use one key for different needs
The activity function will turn on and setup x x x devices
Example
Watch DVD in my setup
the remote will Turn on TV channel 3
Turn on VCR line 2 TV/VCR
Turn on my DVD player.
To access a specific Device menu you would need to select the devices manualy on the remote.
May 22, 2008 | Logitech Harmony 550 Remote Control
Reciever
"no signal" means the unit thinks it is not getting signal from the dish. try reset by holding down the power button on the unit for up to 10 seconds. it will acquire sat and then load guide. this makes the unit "think" again. also check to be sure the cable fitting "stinger" is straight. no signal could also mean the tv or vcr is off channel or is not connected or inputted properly with the original tv remote.
Feb 15, 2008 | RCA DISH Network(r) 311 Satellite System
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Mar 10, 2007 | Panasonic PV-V4021 S-VHS VCR
Black screen
It really sounds like the child lock has been activated. This uaually blocks the keys on the TV, but the remote should work. If your remote doesn't work either, make sure the batteries work. If your remote for the TV can operate other apliances such as a VCR or DVD player, make sure it is in TV mode. If there are any buttons marked TV, VCR, DVD you could try pressing the TV button to set it in TV mode. If the To has a text-tv function there might be more than one button marked TV; one for setting TV mode as posed to DVD operating mode, and one for getting TV picture back when viewing text pages. -Chris
Feb 27, 2007 | Apex Digital AT2008 20" TV
Sony SLV-N750 VHS/S-VHS playback VCR Logo
231 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
