Question about Dyson Ball DC24 Bagless Upright Vacuum
Vacuum shuts off when engaging power head
When I turn on the dyson it runs, but as soon as I step on the release for the power head and push forward the vacuum quits
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC24. Your machine is equipped with a safety device designed to shut the machine down if it starts to overheat. This may be due to a blockage - the filters may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
In normal use, the filters should be washed at least once a month, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filters to dry completely before replacing them.
This should resolve the issue, but if you need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Posted on Feb 13, 2012
  • 1 more comment
  • AskDyson
    AskDyson Feb 13, 2012
    The incorrect video was embedded in my previous response - you can view the correct one here:
    http://www.youtube.com/watch?v=aHKlyvVyy...
    Apologies for any confusion caused.
    Best wishes,
    Jack
  • AskDyson
    Best wishes,
    Jack
  • AskDyson
    Best wishes,
    Jack
chrispurs1
  • 372 Answers
SOURCE: Vacuum head is not staying flat
Hi.
Try changing the short transparant hose under the machine.
Or try removing the hose & reffiting it acts like a spring pivoting the head pushing it flat to the floor.
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
solasknows
  • 199 Answers
SOURCE: Dyson DC07 Cleaner head not pivoting freely.
the spring might be disattachd because of the fall check inside the cleaner head if you can attach it thank you
Posted on May 28, 2009
redbeard00
  • 957 Answers
SOURCE: power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Posted on Nov 08, 2009
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: im having issues with my
    Sorry to hear you're having a problem with your DC14 Animal. You should find the cleaner reclines freely into the vacuuming position when you place a foot on the cleaner head, and lower the handle. If it's not doing this, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can provide the assistance you need.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Jul 25, 2011
    Have a Dyson v6 for several months. Roller brush stops turning a soon as I start to push forward after staring trigger. Examined & cleaned roller & surrounding head & find no objects interfering.
    The Dyson V6 has an electric motor in the power head. The battery is in the handle unit. So power has to get from the battery head unit down to the motor at the floor roller brush. The way they do this is to send the power around the plastic debris cup that you empty, and then into the connector for the tube and out the bottom of the tube to the roller brush motor. Your problem is probably that there is a lost contact along the way. Try plugging the roller brush directly into the head unit leaving the tube out and see if it is intermittent or if it runs fine. In that case the problem is one of the contacts associated with the down tube. If the roller brush is intermittent even when plugged directly into the head unit, then the problem may be the connection associated with the debris cup. remove the cup and make sure the contacts are clean. Hope this helps. G
    Oct 26, 2016 | Dyson Vacuums
    Brushes are not turning on my Dyson 24 vacuum - how can I fix it?
    Hi there, it's Jack at Dyson.
    DC24's cleaner head is protected by a sensor which shuts the brushbar off if something jams it. To reset your DC24's cleaner head, we would recommend following each of the steps shown in the video below. I appreciate you've already tried the reset button, but it's important to follow all of the steps in the process:
    It can help to use something like the eraser-end of a pencil to firmly press the red reset button. You should hear and feel a click as it engages. Please note, the brush bar will never rotate when the machine is standing upright, so make sure you recline it into the normal vacuuming position before testing.
    If you'd like additional assistance after giving this a try, you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson guarantee.
    Feb 10, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson DC33 model. When trying to vacuum flat rug (no pile), the suction is so high the vacuum head is sucked down hard against the rug, making it impossible to push the cleaner forward. This happens with...
    Hi Brad, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty pushing your DC33 on this particular rug. DC33 is a powerful upright vacuum, but we wouldn't normally expect it to be excessively hard to push on any domestic floor surface. However, we may have a tip to resolve this, and we'd value to the chance to discuss this with you directly.
    If you can email your contact details and serial number to us at askdysonUS@dyson.com, one of our experts will be in touch as soon as possible.
    Best wishes,
    Jack
    www.dyson.com
    Oct 11, 2013 | Dyson Vacuums
    The handle will not release to let down to vacuum my rug or floor I havent even had the vacuum for a yr and already messing up paula mcmillion
    Hi Paula, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty reclining your DC17. This sounds very unusual and we'd appreciate the opportunity to run though some quick checks with you to determine what's jamming it in position.
    If you email us at askdysonUS@dyson.com, we'll be in touch as soon as possible. Alternatively, if you'd prefer to give our freephone customer Helpline a call, you can reach us on 1-866-693-9766.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Feb 14, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Rota blade not turning
    Hi Craig,
    I'm sorry to hear you're having difficulties with your DC28. Your machine is equipped with a safety device which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from the brushbar, you should be able to reset the machine. The easiest way to do this is to follow the steps shown in the video below.
    This should resolve the issue, but for any further assistance with your machine, please call us free on 1-866-693-9766 - or if you email us at askdysonUS@dyson.com, someone will be in touch as soon as possible to help.
    Best wishes,
    Jack
    Feb 12, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
    Dyson vacuum head not moving. I release it to vacuum, it releases but then sticks in place
    I'm sorry to hear you're having difficulties with your DC14. The cleaner head should pivot freely as you raise and lower the cleaner body, and lock into position when you stand the cleaner upright. If it doesn't seem to be doing this, it's probably best if you get in touch with us directly so we can help resolve this issue for you as soon as possible.
    You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing for you.
    Kind regards,
    Jack
    Oct 21, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    When I push the release on my Dyson, the vacuum head housing the brush will not lay flat on the floor. The brush still engages and I can use the wand with attachments but I am unable to vacuum the floor.
    Sorry to hear you're having difficulties with your DC25. Due to the nature of your issue, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Aug 20, 2011 | Dyson DC25 All Floors Bagless Upright...
    Black part connecting the drop down foot i do not know how to put it back in please help!! thanks
    Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it.
    Step 1.
    Turn power off and unplug the machine.
    Tilt the machine backward to a 45° angle.
    Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    Jun 15, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
    I cannot get my vacuum in an upright position. How can I do this?
    Try this quick repair and see if this fixes your Dyson:
    Step 1.
    Step 2.
    Step 3.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Apr 12, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson Animal Vac has become hard to push
    Hi there, check that your brush bar is going round if you are having this problem on carpet. When the machine is stood upright, ensure the brush control dial is in the centre position when upright and then moves forward when you release the head.
    If this does not solve the problem call us on 1866MYDYSON as we may be able to run through some more checks to help you.
    Kind regards
    Darran
    Dyson Customer Liaison
    Apr 06, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    14 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
