Question about Kyocera Mita Office Equipment & Supplies
Kyocera km 2820 cannot send the scanned copy docs to my pc. my pc is in the network. what will i do?
Error in sending
SOURCE: SCAN,COPY,FAX PROBLEM
unable to scan,copy or send a fax.I can copy from desktop help R.FARDA
Posted on May 16, 2008
  • 36 Answers
SOURCE: KM-3035 scanning issues
Are you a tech? Do you have the scanner utility installed and running? Do you have the windows firewall on? Do you have some other virus software on? The scanner utility has to be in the exception list. It uses port 139 and it has to be enabled.
Can you pull up the scanner web page? When you set up the scanner utility, you have to create a scanner file destination.
It has to match the destination on the 3035 scan directory.
Or it will say,"unable to find destination". Do you have address book installed? you have to have it on at least one computer?
Posted on Oct 25, 2007
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
  • 25 Answers
SOURCE: ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Posted on Nov 04, 2008
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
Iam able to do a system print out but cannot do a copy
if you can not scan a copy from doc feed or glass may have a bad hard drive. will pull a error code C0640
Jun 21, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera km 3050 a big delay in scan to folder
dose it take awhile to leave the machine or a while to get to the folder because once the machine sends it its done with it check the network situation of the client
Jun 14, 2014 | Kyocera Office Equipment & Supplies
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Km 2820
What error code are you getting? It could be a lot of reason for paper to get stuck, there is always a error code associated with each jam
Nov 23, 2013 | Kyocera Mita Office Equipment & Supplies
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
Scanner problems after Mac Leopard Upgrade
check this link then make sure that you can send a 10 megabyte zip file to that folder from a regular pc with permissions and you can open it without corruption from the mac... if you cann't then you have network problems
Jan 06, 2009 | Kyocera Mita KM-2530 Laser Printer
0x3101 error on kyocera when trying to send scan to email
you can not scan usb, it has to scan via network cable via the scan card . you can use quicksetup utility to log in to the scan card and change the destination ip address of your tower. as long as your tower has a static IP sddress , should be applied via web interface of the scan card..
Nov 02, 2008 | Kyocera Office Equipment & Supplies
316 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
