Hi, how does one set and check the FSB speed? I can't find any motherboard diagram indicating jumpers nor settings nor BIOS setup (in Acer manuals) for this.
I understand P4 can go to 800Mhz and Celeron to 400MHz.
CPU-Z version 1.34.1. says I have the following:
CPU(s)
Number of CPUs
Name
Intel Celeron
Code Name
Northwood
Specification
Intel(R) Celeron(R) CPU 2.60GHz
Family / Model / Stepping
F 2 9
Extended Family / Model
0 0
Brand ID
10
Package
mPGA-478
Core Stepping
D1
Technology
0.13 um
Supported Instructions Sets
MMX, SSE, SSE2
CPU Clock Speed
2593.6 MHz
Clock multiplier
x 26.0
Front Side Bus Frequency
99.8 MHz
Bus Speed
399.0 MHz
L1 Data Cache
8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache
12 Kuops, 8-way set associative
L2 Cache
128 KBytes, 2-way set associative, 64 Bytes line size
L2 Speed
2593.6 MHz (Full)
L2 Location
On Chip
L2 Data Prefetch Logic
yes
L2 Bus Width
256 bits
Mainboard and chipset
Motherboard manufacturer
Acer
Motherboard model
J88M, (null)
BIOS vendor
Phoenix Technologies, LTD
BIOS revision
6.00 PG
BIOS release date
04/06/2004
Chipset
Intel i865P/PE/G/i848P rev. A2
Southbridge
Intel 82801EB (ICH5) rev. 02
Sensor chip
SMSC 6001
FSB Select
400 MHz
Performance Mode
enabled
Graphic Interface
AGP
AGP Status
enabled, rev. 3.0
AGP Data Transfer Rate
8x
AGP Max Rate
8x
AGP Side Band Addressing
supported, enabled
Memory
DRAM Type
DDR-SDRAM
DRAM Size
2048 MBytes
DRAM Frequency
133.0 MHz
FSB:DRAM
3:4
CAS# Latency
2.5 clocks
RAS# to CAS#
2 clocks
RAS# Precharge
2 clocks
Cycle Time (TRAS)
6 clocks
# of memory modules
Module 0
A-Data Technology DDR PC3200 - 1024 MBytes
Module 1
Software
Windows version
Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version
9.0c
Maybe it's already running at 400Mhz but why is
99.8 MHz
shown?
Any help appreciated!
Regards, Gerry.
Hi Gerry,
The understanding of how this works will require some study on your part. This is because you would not have enough basic knowledge to understand any short answers, that someone might give.
Here are some resources for you to read so you will understand this subject.
http://computer.howstuffworks.com/motherboard4.htm
http://www.directron.com/fsbguide.html
http://en.wikipedia.org/wiki/Front_side_bus
I hope you will find the answers you are looking for here.
Good luck.
Thanks - http://www.directron.com/fsbguide.html is a definite must read!
A short answer would be fine but glad for that info. - I have a reasonable knowledge but was looking for some reassurance I guess. I'm assuming now it's running at 400 (100x4) but in the past I was used to m/board jumpers - this seems newer (no such jumpers - only BIOS).
cheers kleeper, Gerry.
