Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Changing rear outer shell
I,d like to know how to replace rear outer shell--I haven,t had to do one &
now I have 2 on order.
  • Rene Matz Oct 30, 2008
    Yes--I think your info will be a great help.
    Thanks
  • 728 Answers
I am guessing it is a dryer. If it is, then unplug it first, and remove the dryer hose that handles the extra air and lint and any other hoses that are connected to it. After that take the screws out of the back and cautiously remove the back slowly just in case there are cords connected to it in some way. Take the new back and put it on making sure it is on the right side and that it is clear of cords. Put the screws back in and reconnect the hose(s). Plug it back up and it should work.
Posted on Oct 29, 2008
  • Jazz Boyce
    Jazz Boyce Oct 29, 2008
    If it is a washer, unplug it and make sure all of the water is drained out before disconnecting the cold, hot, and draining water nozzles. Follow the same steps as above and it should work.
  • Jazz Boyce
    Make sure you run the hoses back through the holes in the back once you take them out and put the new one back on.
    Scholar:
  • 155 Answers
Please tell the exact model number to explain you better.
quickly.
  • fixexpert Oct 29, 2008
    http://www.applianceaid.com/boot.html
    check out this link.
    read the instructions
    Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
    2. Loosen two screws that hold weight on back half and slide out weight.
    3. Remove drive belt. Cut wire tie, unplug motor and leave wiring in the bottom of the washer. Remove 4 screws/bolts that hold on motor and remove motor.
    4. On front right, loosen screw and remove rubber drain trap from tub. Squeeze large snap ring and remove water level sensor ( thing that looks like an old fuel filter ) from rubber drain also. Remove little hose from top of water level switch also. ( NOTE: You can also disconnect the level switch hose at the top of the washer. This will make it easier to re-connect, however you'll need to be careful that you do not damage the hose when you remove the tub assembly ).
    5. At this point, you might want to remove the motor control board and pump motor assembly. Each is secured by 2 screws and are easily removed. This will prevent accidental damage and give you more room inside the washer to work with. There are 2 connectors on the control board and 1 on the pump motor ? be sure to remove those first.
    6. Shocks, push the lock tab to allow the pin to be slid out of the tub and the shock will be free from the drum. ( picture help one and picture help two )Push pins through to the rear and remove. The baskets will now be hanging from the springs.
    7. From top, twist out the tube from top of the outer tank. Place support under drum. I use 2 blocks of wood.
    8. From front, carefully cut the glued spots where the door seal is glued to the front panel and remove the fill spout holder clip. The tools used is a piece of copper tubing flattened down. I use a wire tie to reinstall as the metal clip can be a pain to work with!
    9. Drum should just be hanging from 2 large springs. Remove the clips/spring holders that go over the top of the springs so they can be lifted and removed from the washer. Start on either side, lift spring, move toward center and lower to disconnect drum from the frame. Completely remove spring. Repeat on the other side. Drum should now be sitting on the supports.
    10. From above, lift drum and slide out the rear. Leaves you with an empty cabinet.
    11. Lay drum on front face on a blanket or sheet and start to remove screws that hold halves together. Once all screws are out, the back half with pulley (top half if sitting on face) easily lifts up from the other half.
    12. Remove and replace tub gasket seal. New seal will appear thicker than old one. The old seal can be picked out with a small flat screwdriver.
    Assembly.
    13. Place supports in bottom of washer. Lift and slide drum back into place on top of supports.
    14. I use a zip/wire tie to go around the water fill tube where the spring clip was and then cut the leftover tail off of the zip/wire tie. I remove the 2 screws holding the plastic hose in place to make installing the wire tie easier. Push the rubber boot over the plastic hose and use the wire tie to secure the boot to the plastic hose. Helps to install drum support springs (big ones on top) first.
    15. Install safety clips back over springs. Glue the top hose back into place.
    16. Front assembly reverse of disassembly.
    17. Back and Motor assemble reverse of disassembly.
    18. Finally, pull the boot over the front of washer. Don't do this until drum is in fully, or the boot might not end up on straight and might twist a bit. Small spots are re-glued again in place, super glue works well for this.. Spot glue at the 12 o'clock, 1, 2, 3, 4, 5, 6, 7, 8 and 9 o'clock positions around the opening.
    19. Put on back and top.
    20. Run load, check for leaks. Note: back panel is structural and should be on for a load to be run.
    21. Should be done. Total time 3+ hours. I hope this helps anyone who has to get into the Frigidaire - Kenmore ( 417.###### ) front loader and replace the seal/tub bearing&shell or inner basket.
    rate the solution if helped.
    keep updared.
    thanks.
I am trying to buy my son a Nitro snowboard for xmas and would like to know if I need to order a wide board. He is 5ft 11inchs and a size 10 1/2.
You should not need to order a wide. The length of his board is heavily dependent on his weight. If he were on anything less then a 157, you could be comcerned, but a number of their boards are available in a mid-wide.The size of board designed for his body weight and in general, his height, should get him into a wide enough boot to fit his feet.
Although, the tendency is definitely to go shorter then the camber of the board is designed and this can be appropriate/affected by terrain and riding style. Be a little weary of choosing to small of a board.
Another key would be the brand of boots he has or gets. Some brands use two size liners in the same outer shell. Burton is a good choice in boots with their one-to-one size shell and liners. Giving the rider the smallest outer shell possible in relation to their liner.
Nov 26, 2012 | Nitro Winter Sports
Changing the light bulb
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
Regards.
Jan 05, 2012 | Panasonic NN-H264 Microwave Oven
Top loading #110.29842990 Outer shell came
The outer case catches under the frame across the front and there is a tab on either side on the frame near the back these tabs go into a slot in the flange on the bottom of the case. You may need to loosen the control console to do this. 1. Disconnect the power. 2. Remove two screws, one at each top corner on rear of console. 3. Push a putty knife under the front of the console near the corner. You will feel the resistance from a spring steel clip. Push, firmly toward rear of machine. clip will release and console will be loose. Repeat at other front corner of console. 4. make sure outer case is hooked under front of frame. 5. Put case on both tabs(check at rear corners on back of machine to assure that back panel and case corner are in the modling that aligns the two. This is sometimes like a wrestling match. Take your time it can be a test of your patience. It is helpful to see diagrams available at www.sears.com under Parts direct. Find your model number and an exploded view is available. Good luck.
Jun 30, 2009 | Kenmore Washing Machines
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Picture1 - Picture2
May 07, 2009 | GE WJSR2070B Top Load Washer
Maytag washer MAV551EEWW top load with loose tub
Picture1 - Picture2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Made a loud noise and drum stopped moving
Picture1 - Picture2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Washer GLTF2070DS0
warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
141 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
