Question about Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard
Stopped recognizing devices after inserting different hardrive and cdrom
I recently updated the bios,it took 2days!! everything was fine until i tried to add another hard drive 20gb and different cd-rom.Now it won't boot into setup even after i switch jumpers to configure mode,where as it was before.For some bizarre reason it only reads from my floppy after giving me a B:drive error message and I don't even have another floppy(B:) drive.I tried to configure my C: drive using w98 startup disk,but one minute it recogonizes C: drive,but when trying to format or do anything with it,it has invalid error messages(parameter invalid, or bad command).I can't even access my cdrom drive and it was working fine.TRULY BIZZARE.SOMEONE PLEASE HELP ME,BECAUSE IT'S A FRIENDS COMPUTER AND i TOLD HIM I COULD FIX IT AND NORMALLY I CAN!!
  • 254 Answers
SOURCE: BIOS ROM checksum error
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Posted on Jan 05, 2009
  • 238 Answers
SOURCE: bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Posted on Jan 23, 2009
  • 45 Answers
SOURCE: turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Posted on Mar 22, 2009
SOURCE: Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
the three beeps mean that your RAM is not good,and can be because of your memory slot;try changing the memory slot,or RAM memory;enter bios and disable floppy,and review the boot order.
Posted on Jun 24, 2009
  • 4090 Answers
SOURCE: My pc won't boot from
you are saying two differnt things here.. CDROM and DVD if its a dvd in a CD ROM it will not boot a windows disk if somehow this is written to a DVD Is it original?
Secondly is the Cd ( or DVD drive) actaully working. Being listed in CMOS does not guarantee that.
I know you have listed the drive as DVD but do you have 1 or two drives installed and not have the disk in the recognised drive.; have to eliminatge all possibilities of werror in interpretation here.
So assuming everything appears as it should, then the medial in the drive has to be considered at fault .. dirty disk.. drive needs iris clean, not an original disk, damaged disk, not a boot disk.. just a windows cvopy.;
Posted on Nov 23, 2009
Hello, I have a Packard Bell branded laptop displaying the error there is no boot disk see details and the photos in first comment to know what happens and did someone can help me with it?!
If you set the boot order to USB first boot device and HD second. Insert USB and boot from there. It should find your HD and then you can install your OS. Another system for a different laptop will not work!
Jun 15, 2016 | Packard Bell Computers & Internet
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Dell D620 USB device not recognized
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
May 23, 2017 | Dell Latitude D620 Notebook
I have a 250GB Buffalo Turbo USB Hardrive. Until today it was working fine. Now suddenly it says USB Driver not recognized. Whats the problem?
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
Oct 30, 2009 | Buffalo Technology 250GB MINISTATION TURBO...
Disk boot failure, insert system disk and press enter -ax1200
Hardrive is gone. dear. replace it. check if there is any floppy or cd in the tray. if not replace the hdd.
Oct 01, 2009 | AcerPower 1000 - Athlon 64 3800+ 2.4 GHz...
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
Erase everything from my hardrive,start fom cero
You can erase all the data in your harddrive by formatting it. If you have installer of windows insert it to the cdrom or dvd and change the booting options in the cmos or bios setup to boot in the cdrom. Reboot the computer in follow the instruction how to install in format the hard disk. Delete the partitions and create a new one to avoid the virus stay in the sector of the disk
Apr 15, 2008 | Computers & Internet
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
