Question about Genie Company G912 Genie 912 One Button
My light on my Genie GXL 9500 won't shut off
Genie Garage Door Opener GXL 9500
blanchettohd
  • 143 Answers
SOURCE: The motor on my Genie Chain Glide garage door
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Posted on Sep 03, 2010
blanchettohd
  • 143 Answers
SOURCE: Genie Garage door will not
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Posted on Nov 06, 2010
blanchettohd
  • 143 Answers
SOURCE: own late model 12hp Genie
It will be on the outer surface of the motor head, or under the light cover. It will be the only one you can press. Some older units have dip switches which look like a row of toggle switches. If so there will be no learn button. Thanks BB
blanchettohd
  • 143 Answers
SOURCE: genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
  • 9 Answers
SOURCE: Genie model ACSD1G will not program to Linear door
Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a how-to video.
Posted on Mar 03, 2011
How do I reset a password for a genie pad on garage?
try this:
http://homeappliance.manualsonline.com/manuals/mfg/genie/sd9500_9.html?p=1
Nov 24, 2015 | Building Materials
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
A friend has a Genie model H6000A garage door opener. The previous owners don't have a remote and I cannot find either a smart button or the little tags to toggle. Please help!
they'll need a new Genie Master Remote for that opener, and the learn button should be under the light cover on the right hand side. You should be able to see a red light near it.
Sep 15, 2013 | Building Materials
Can Genie Wireless Keypad work for door w/o LEARN button?
If the keypad doesn't have dip switches it will not work with that opener.
Jun 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Genie Company G912 Genie 912 One Button Logo
150 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
