Question about Microsoft Xbox 360 Console
Xbox live connect
IP address keep failing
  • 1 more comment
  • frenchfry101 Nov 02, 2008
    ip keeps failing
  • mels_dope_xD Dec 06, 2008
    ughhhh i have the same problem my xbox live ip adress says failed should i put it in manualy what do i put ? HELP
  • howardcedric Apr 10, 2009
    ip keeps failing
    Problem Solver:
  • 14 Answers
Assign static IP addresses for everything connected to your router! If the IP address is failing it means there is a conflict. This site might help you out a bit
http://howtoconnectwirelesslytoxboxlive.blogspot.com/
Posted on Jan 09, 2009
Pleace can oyu tell how to fix this problem
Posted on Dec 07, 2008
My ip keep failed
Posted on Oct 25, 2008
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
It wont go on live it keeps sayin fail when i try to connect
What does it say? For example ( IP Address failed?, DNS failed? Xbox Live Failed )
test your xbox live connection to do this
Mar 27, 2009 | Microsoft Xbox 360 Console
Ip address keeps failing
Hi , Do you have static IP in place , i mean in network neighborhood type your IP and make it as the permanent, then log in , you will be able to access.If you dont know how then surf the net to manually type static IP.
Jan 17, 2009 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 live
find the IP adress on ur router if its wirless
May 16, 2008 | Microsoft Xbox 360 Console
IP address
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Apr 13, 2008 | Microsoft Xbox 360 Console
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
110 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
