Question about KLH ASW10-120 Subwoofer
Where can I buy printed circuit board for a KLH 6.5 subwoofer?
Circuit board is burned out
    Top Expert:
  • KLH Master
  • 73,740 Answers
Hello
It will be very difficult to get its printed circuit board as it is. You can buy a populated board to your KLH from Ebay. Just search in with its part number.
Posted on Feb 12, 2012
Bennytechkid
  • 99 Answers
SOURCE: i have a klh subwoofer about 6 yrs old.it keeps
Okay sounds like there is Fault in the power supply or the output transistor have shorted and is pumping the driver with DC....remove the driver and test with a muti-meter and using the 200 Ohm setting. put it across the terminals of the subwoofer make sure it is disconnected from the amp module....if it is a 8 ohm driver you may get somewhere from 4-8 ohm reading if its a 4 ohm somewhere from 3-6 ohms....if you are getting a 0 ohm or "short" or a really high or infinity "open" reading then the driver probably has caused damaged to the output transistors in the amplifier module. connect the muti-meter to to the red a black leads from the amp module that was going to the speaker...put the muti-meter on the highest possible DC voltage setting Mine goes to 1000VDC and power up the sub amp module now you may get a jump and power up but then it will drop to around 1.0v (or less) that is normal but if it stays high like anywhere from 30-150 VDC then you have blown output transistors (remember if you dont have this issue just skip forward!)...if this is the case pull out the amp module (remember to follow warnings and disconnect from mains power) now the DC filter caps in the module stay charged for long time after power is removed remember: test before touching!! now hopefuly all transistors are laid out infront and you wont have to dig for them the're normally are mounted flat and bolted to a external heatsink on the back. test between all junctions of the transistors B+E C+E C+B make sure there are no shorts...if there is a short replace the transistor. across from it there is its partner...replace him to! more than likely he's faulty because they work in whats called a Complimentary pair...the PNP pulls up the postive and the NPN pulls up the negative..together making a full audio signal. now after replacing all the faulty transistors test for DC on output leads. If there is none carefully connect a NEW driver of the same impendance as the old one.....but do not connect up the old one because you will blow the amp again....now power up and test for sound....all good????
Now if there is NO DC leaking on the Output leads but its still blows fuses there is a power supply fault! pull out the amp module now there is two types of power supply that this sub (or any amp for that matter) uses Switchmode Power supply (SMPS) or the normal transformer supply.im hoping for your sake it is a normal transformer supply it makes it soo much easier to fix....now be very careful you need to check the DC filter capacitors for shorting or any other issues! so undo the board from whatever it is mounted on, now remeber these capcitors can stay charged for along time so be sure to test before touching...if they are still charged and you want to dischrge them i use a 100W bulb (not an energy effiecnt bulb...but a Normal filament globe ) and connect up two leads to it...now put it across the capcitor banks...it will glow brightly and it will slowly dimm....power discharged!!
remeber to check that all caps are fully discharged!!
now test with muti-meter again on ohms mode and check for any shorts...now as you test the resistance will get greater as the caps charge up...this means all is good but if the meter stays at short then you have an issue with one of the filter caps (now if there is a short the caps will not have charge in them but still test!!) Now carefully remove each cap and test to finally locate the shorted one(s)...if there is no fault in Filter caps i would check the power transformer on the primarys so disconnect the leads from the power input socket (remembering the whole time we're doing this power is disconnected!!) and check with ohms meter there could be fault in which case you need to get a new transformer..if its not a faulty transformer.. i would be checking all mains power connections: the switch,interconnection leads,the fuse holder ect...to make sure there is no shorts...now if the power supply is a switchmode supply i would not even go there! i can repair them but it is way to hard to describe here and is not suggested for a DIY'er to attempt to repair but if its 6 years old it should be the way i have described above (normal transformer supply)......feel free to contact me if you need some more help in repairing this..E: ben@xdcpro.com.au
Depending where you are in the world most of the parts for amps can be sourced at local electronic stores or you could ask local repair stores to order parts in for you..if you are in Australia..if you want you can send me the numbers on the parts i can arrange them for you and post them out to you! good luck and i hope this can fix it,ben
Posted on Aug 11, 2009
  • 547 Answers
SOURCE: Have the KLH ASW10-120 Powered Subwoofer and it is blowing fuses
This model has a high failure rate with the power supply board. Typically, power resistors fail, which in turn burns out the big capacitors.
I have not heard of transformers failing though, so it shouldn't be too much to repair it.
Here are the schematics for the unit: Upper board and Lower board
Posted on Jan 11, 2010
renosean
  • 492 Answers
SOURCE: klh subwoofer asw80-80
Unfortunatly it is due to the wiring within the house. Short of buying an apc back up which will regulate the power there is not a powerstrip that will stop this. I used to have the same problem
Posted on Mar 08, 2008
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Posted on Jan 31, 2010
I burned up some resistors in my klh asw120 # r52 r48 and r49 i need the values to them so i can replace them they are too burnt to tell the color code please get back to me with the values! Thanks JASON
This is a pretty common problem with this sub.
Here's a solution that I posted earlier this year, including schematics for the upper and lower circuit boards. Be sure to check the circuit board revisions to make sure they match my schematics.
Aug 10, 2010 | KLH ASW10-120 Subwoofer
Tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
on Sep 25, 2009 | KLH ASW10-120 Subwoofer
Hum no audio output
There are a lot of folks who've had power supply issues with this sub. Typically, the large resistors fail, which takes out the capacitors.
If you know how to read schematics and replace parts, then these might be helpful to you:
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Dec 22, 2009 | KLH ASW10-120 Subwoofer
If it stays on for 3 seconds then it probally is not the transformer. However it may very well be the power amp no way to tell untill we operate. Call Pro Line Music 215-736-8055
Dec 11, 2009 | KLH ASW10-120 Subwoofer
No sound and smells like burning
Here are the two pages of schematics from KLH. I wrote to their techdepartment and explicitly asked for permission to share them here.
Nov 08, 2009 | KLH ASW10-120 Subwoofer
Burns [blows out the 50v bridge rect] on power up. cant find the short??? all conds and resistors seem to check out OK ??? The four Z-diodes seem ok also ??? All transistors seem ok [no low ohms-only...
I'd suspect the 6800uF caps, but I don't know for sure.
If it helps, here are the schematics for the upper and lower boards:
Upper board
Lower board
I wrote to KLH to ask for them, and explicitly asked for permission to post them here.
Jun 15, 2009 | KLH ASW10-120 Subwoofer
Burning smell
The amps do have issues that is for sure - That is where I step in - I can repair your amp and make it so it won't burn up (catch on fire) again. When the amp goes it burns a hole in the board - but it can be repaired. I have done several hundred and all customers are happy :) ... Look for my add here and also on ebay
May 12, 2008 | KLH ASW10-120 Subwoofer
Info
I wrote to KLH and they sent me the schematics for the upper and lower boards. I asked if I could share them, and they gave me permission to post them for use here.
Have fun!
Mar 10, 2008 | KLH ASW10-120 Subwoofer
Klh subwoofer asw80-80
Feb 18, 2008 | KLH ASW10-120 Subwoofer
KLH ASW10-120B subwoofer
I realize that this is an old problem, but folks are still finding it on searches, so here goes.
Jan 25, 2008 | KLH ASW10-120 Subwoofer
KLH ASW10-120 Subwoofer Logo
208 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
