Question about Canonical Ltd. Ubuntu
Autorun exe on ubuntu
Need to find a program that will open and autorun a hdtv dvb-t dongle and its files on ubuntu
  • 44 Answers
Please refer to this PDF for info on your problem..
http://lifastleg1680.com/download/DVB_T_user_manual.pdf
Posted on Feb 12, 2012
  • tmaree
    tmaree Aug 10, 2012
    Hi the link you supplied has been removed or it's name has changed. Thank you for trying to help though. Do you have any other suggestions? Thanks again
  • tmaree
    tmaree Aug 10, 2012
    AbdulRahiman S - yes that is something I knew, and I have tried wine, with no positive results however. Can you suggest how to use wine to do this? Thanks
3 Suggested Answers
  • 306 Answers
SOURCE: how to install .exe files
Linux doesn't uses .exe files. Our executables are made in a different manner.
Since the app is a Windows app (hence the .exe), my recommendation would be to install it on a Windows partition (if you have one), and access it with WINE.
I don't think that WINE can install onto the Linux partitions, but you might give that a shot, by simply running the installer with WINE.
Posted on Aug 30, 2008
  • 62 Answers
SOURCE: I,m running ubuntu desktop 10
most usb modems are set up for windows by default so you have to ask the usb modem provider for the ubuntu driver..
Posted on Sep 02, 2010
I am using a Transcend 8GB USB Pend Driver. when i scanned it, it showed me that, find "rahulvirusprotection.vbe". Hence i delete it immediately. After deleting the virus, i tried to access the...
It is virus which uses autorun feature of the removable devices such as USB Pen Drive. These type of viruses usually have two files. (a) autorun.inf and (b) the executable (.exe) or script file. Some Antivirus programs delete the exe file but the autorun files remains. In your case, the exe file (rahul's virus protection.vbe) has been removed but the autorun entry is there, which is run everytime you try to access your pen drive. First, plug-in the drive and DONT OPEN IT. Open 'My Computer' , right click the pen drive and choose explore. (This would by-pass the autorun feature).
Download Flash Disinfector and save it to your desktop. Double-click Flash Disinfector.exe to run it and follow any prompts that may appear. The utility may ask you to insert your flash drive. Please do so and allow the utility to clean up those drives as well. Wait until it has finished scanning and then exit the program.
Reboot your computer when done.
(Flash_Disinfector will remove any autorun.inf files, create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran it. Don't delete this folder. It will help protect your drives from future infection)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | Office Equipment & Supplies
How to autorun swf file from cd which command shud give for autorun particular swf.file
Open a text document and type this in.
[autorun]
OPEN=STARTUP.EXE
"startup.exe" should be the name of your flash executable file.
Jul 20, 2010 | Macromedia Flash Professional 8.0 Full...
How to open .exe file in ubuntu operating system?
try to install wine player in ubuntu so tht u can install windows apps in linux..!!
Feb 03, 2010 | LeapFrog ClickStart My First Computer...
Autorun a .exe automatically off a USB drive.
Open Notepad Type in: [autorun] open=PStart.exe action=Run PStart Program icon=PStart.exe label=My Portable PC Save the file as autorun.inf Put the file in the root of your USB flash drive The next time you insert your removable drive into your PC, the specified program will autorun from the USB drive
Of course you use your own names at the Commands.
Jan 26, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Autorun.inf doesn't open file in internet browser
Hello ksharp628,
I use a program called autorun.exe One limitation of the standard AutoRun facility is the fact that it will only run executable programs; it will not by itself open document files such as web pages or text files. AutoRun.exe is designed to circumvent this restriction: it will open any number of document files or start executable programs. Moreover, it is smart enough to use a sensible fall-back strategy if no documents can be opened, perhaps because the target system does not have the required support for those document types.
example of my autorun.inf
[autorun]
open=autorun.exe msn.html
action=Run MSN.com
icon=msn.ico
in root of thumb drive I have Autorun.exe Autorun.inf MSN.html and my ICON msn.ico wich i did a search for on my computer
I hade t make and msn.html
my edited msn.html file open in txt format
<meta HTTP-EQUIV="REFRESH" content="0; url=http://www.msn.com">
You can replace with what ever website you want and rename it to that.
This autrun.inf setup will popup the autrun box and ask you pick an option. this is as close to running the webpage when inserting the usb drive. The program comes with a .pdf on many options wich can be used with autorun.exe.
the link to the autrun.exe program is found below.
http://www.tarma.com/products/autorun/
Hope this helps you, take care.
May 05, 2009 | Dell Dimension 4600 PC Desktop
No autorun on usb devices or cd rom
run AutoFix.exe
download clik here Windows XP autorun repair wizard
Applies to:
Windows XP with Service Pack 2
Requirements
Windows XP with SP2
window.google_render
File Size
0.1MB
File Name
AutoFix.exe
Author/Supplier
Microsoft
Description
Windows XP was designed to make it simpler to identify content on CDs or DVDs, and assist in launching the correct program to open or view the files. For example, insert a movie DVD and Windows XP should show options for programs that can play a DVD. Unfortunately things can go wrong - settings get altered and the autorun no longer wants to be your friend. This free tool can help diagnose and repair autorun problems in XP. It is a tiny download and doesn't require installation. Simply double-click the exe file, click a few buttons (OK, some options are a little cryptic) and you can change or repair your Windows XP autorun options.
Jan 10, 2009 | Microsoft Windows XP Home Edition
Funny UST scandal virus
its a virus infection... if you have updated viruscan database scan /cleaning it.. run it in safe mode..if not works, backup your important file and format your hard disk..
Apr 09, 2008 | Computers & Internet
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Jan 24, 2008 | Computers & Internet
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Canonical Ltd. Ubuntu Logo
124 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
Dennis Gutowski
Dennis Gutowski
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
