Question about Intel Pentium IV M, 3.06 GHz Pentium 4-M (SL77P) Processor
Laptop acts like CPU is overheating - after ~ 15 mins. computer slows to crawl, both fans start and never stop running.
My laptop, which has been working great for the past 6 years, had 1 GB free on a 20 GB hard drive. To free space I removed several programs including Norton SystemWorks. I also added a USB Linksys Wireless device and driver to connect my recently subscribed DSL connection. It was around this time that I noticed that after about 15 minutes of running the two fans at the rear of the laptop would come on and never shut off. Also, the computer would start to slow down to the point of making any browsing impossible.
I purchased “The Ultimate Troubleshooter” to see what I could find. Besides some minor program issues and suggestions, which when corrected did nothing for the slow down issue, I did notice the “Load Unload Cycle Count” was not “OK”. My understanding is that this is a hard drive problem and should not cause an overheating processor-like symptom. I also took the keyboard off to see if the inside of the computer was dirty, but everything was clean (I monthly use canned air to clean the grill). I did notice that, when taking the heat plate off from the processor, there was no adhesive. This did not seem to be a problem for six years, so I doubt this is the cause of the slow down (I did make sure no oils from my hands touched the processor or plate).
The processor does slow down, so it should be able to cool. The Pentium III does not have a heat sensor, so I don’t know the temperatures involved. It does not appear to be enough to shut down the computer.
Is the processor going bad? Does the plate and processor need thermo adhesive? Could the Load Unload Cycle Count be the cause of the slow down? Did I remove something critical when I uninstalled the programs? Do I have a bad driver (all appear to be up to date)?
I would appreciate any help or advise you can provide.
Thank you,
Francis Scott Zimmer
fsz@dreamscape.com
  • 29 Answers
I agree with Joe Boss. with only 1G of free space, you don't have much room for a swap file. Removing your keyboard and using compressed air can be good and bad. Some heat sink/cooling fan assemblies need to cleaned out from the outside in (to remove dust and etc from the inside of the cooling fins) otherwise the cpu could get hot and slow down.
Posted on Feb 12, 2009
  • 59 Answers
Sounds like the hdd is just loaded if all you have freei s 1 gb and that makes the cpu move slower no if 6 yrs aith out goop is fine not that.
1. I suggest backing up only important personal data and formating & reloading the original (prefered oem xp for example) or any upgraded os you have access to eith software or some computers have a recovery process on the hard drive ( hit f X to start recovery process) this will clean all the junk off & give you back your original speed only install what programs / data needed use a good antivirus such as avast and antispyware such as defender from windows
Posted on Oct 24, 2008
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
Tip
How to stop over heating laptops or computers.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
The most common cause of laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your laptop. This causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just Hot. Laptops get hot. It's what they do. However, if your laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link...
laptop over heating Google Search
on Oct 24, 2017 | Computers & Internet
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 06, 2011 | Computers & Internet
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My ACER 5100-4720 boots up with a black screen and after about 15 minutes it loads Windows Vista, but it is very sluggish, then it acts like it gets up to speed and still runs sluggish. I have 1GB DDR2,...
The first thing I would check is that the cpu fan is working. You should be able to see the fan come on from the bottom of the laptop. Sometimes the fans can stick from dust and dirt. Then the cpu will get very hot and cause the computer to slow way down. Try using a can of compressed air on the fan and see if it starts working. If the fan is working ok then you might have some type of virus or corrupted installation causing the computer to slow way down. You could try pressing F8 right before windows starts to load. This will bring up a boot menu. Then try booting the computer in safe mode with networking and see if it boots up fairly quickly. Once it boots up in safe mode run your virus scanning software to see if there are any viruses on your computer.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Overheating Dell D600?
It is overheating. This is the #1 killer for cpu's. First check all your vents to make sure they are dust free and blowing air out. If they are then you'll want to either upgrade your cpu fan or you could buy one of those laptap cooling pads to keep the laptop on while in use. Hope this helps.
Jun 01, 2009 | Dell Latitude D600 Notebook
CPU fan issues
The fan may not stay on all the time - its a feature of laptops to help save power. The fan is also variable speed. As the CPU gets hotter, the fan speeds up. When the CPU isn't being used as much and is cooler, the fan slows or even stops. It turns on to full speed when you first turn the laptop on as part of the BIOS system check.
The noise is another issue. You could have a broken "fin" or fan blade. The bearing could be going out. Something may have simply "crawled" inside the fan's output vent. In any case it may be worth your time to have a professional open up the laptop and look at the fan. I have heard a LOT of noisy laptop fans in my day, and believe me it's not the worst thing to put up with.
Mar 19, 2009 | IBM ThinkPad T42 Notebook
Fan starts runnung fast and everything is frozen
Overheating. Try using canned air and blowing out vents. If you are comfortable with it, take the laptop apart and clean it out. If not, contact a local computer shop that can do it for you. If cleaning doesn't do it, the CPU heatsink will need reseated or the CPU will need replaced.
Jan 15, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
Fan on laptop intermittent Avent 7110
That can be normal. Normally cpu fans start up only when cpu reach a determined temperature. After it cools down it stops until temperature reaches starting point again.
Generally, when the fan is not working properly, the computer turns itself off after a while because of overheating.
If you have this problem, laptop turning itself off because of overheating (check it is not hibernating etc.), then you usually solve it by replacing the laptop cooling fan.
Generally, 'fan on laptop intermittent' is not a symptom of malfunction.
Apr 25, 2008 | Computers & Internet
Computers & Internet Logo
296 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
