Question about LG DLE3733 Electric Dryer
Tub not turning - LG DLE3733 Electric Dryer
  • tmaree
    tmaree Feb 12, 2012
    do you know the year it was manufactured? Because some use a drive band (which may have worn away) and others use a gear joint that stupidly have plastic gear bushes which tend to snap.
  • 1,959 Answers
Likely a broken drive belt. A video below demonstrates taking apart and belt replacement on a typical LG dryer.
Posted on Feb 12, 2012
Belt le7680xsn2 whirlpool
Only thing that fixes itself after cooling is the main motor. Either motor is failing, or something is binding preventing tub from turning, or making tub hard to turn. Can have hair binding support rollers. Will need to turn tub by hand , counter clockwise to determine if it's hard to turn, if so remove tub and inspect rollers, if they don't turn freely replace rollers.
Aug 12, 2014 | Whirlpool Dryers
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
What is code oL
Ol is rarely actually over loaded. Check the tub by pulling up on it. You should get a slight movement .The tub floats .if if doesn't the shaft and tub will need to be cleaned with sand paper. Also check for obstruction under the tub. Turn the tub by hand it should turn freely. Good luck.
Apr 26, 2014 | Whirlpool Cabrio WTW6600SBK
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I am replacing a bathtub lift and turn tub drain w/ the Danze lift and turn tub drain conversion kit- how do i remove it from the part that stays in the tub? I just want to put the pull into the existing...
Unless you can get to the bottom of the tub either through the floor below or the wall in front of the tub.... you do not want to do that...
To change it you may need to change some of the piping to the tub drain....
It is possible that you can take a needle nose pliers and turn the tub piece out by sticking the pliers through the webing in the tub drain and turn the CCW also.....but if the bottom piece is not the same thread.. or the piece moves... you may not be able to get the new piece started and then your in BIG trouble...
heatman101
May 11, 2011 | Danze D490637 Lift & Turn Tub Drain &...
How to turn on hot tub
Hot tubs do not have an "on" button. They are preset to heat up to 100 as soon as the breaker is turned on.
May 31, 2009 | Qca Spas Paradise Hot Tub
Good power, tub will not turn
tub, is the lid switch plugged in? If not take a jumper wire and jump out the two ends on the harness. Timer controls recirculation and spin. The motor turns both ways. The spin cycle goes through the lid switch. Catriver..post back
Feb 27, 2007 | Whirlpool LSQ8000 Top Load Washer
LG DLE3733 Electric Dryer Logo
82 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
