Question about Magnavox 40MF430B LCD TV
Popping noise and now the sound is distorted. its like a static and vibration coming from the speakers. why is this happening? how do i fix it?
    Top Expert:
  • Magnavox Master
  • 75,283 Answers
Hello
The audio output section of your TV has damaged. The set need a through checkup, before replacing this board; especially to the voltage input to it, from the power supply board need special care.
Posted on Feb 12, 2012
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Steady popping noise.
Hi
reinstall the sound driver
thank you
Oct 23, 2008 | Logitech Z-5500 Computer Speakers
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
I recently purchased a 52 inch LCD. I have
This could be the speakers are vibrating onto the casing and need padding out more to prevent this.If this isnt the case, you may have a sticking coil on one of your speakers..When the sound distorts, remove one speaker in turn to see which one(s) are the offending unit(s) and replace. Is there a buzzing noise coming from the speakers especially in low volume? If so then you may have a faulty capacitor in your power supply producing hum on sound. Hope this helps :)
Oct 17, 2009 | Toshiba Televison & Video
Logitech Notebook Quickcam (SOUND PROBLEM)
Normal 0 If you have your speakers turned up to high it will give you feedback causing distortion and static. Sometimes even awith the speakers turned down low, feedback is possible.
I recommend using a headset when videoing. Hope this is of some help. Bud
Apr 22, 2009 | Logitech QuickCam Webcam
Popping static noise SyncMaster 150mp
Are you still having problems with this monitor?
I posted about a "clicking" sound that has to do with failed capacitors near the speakers' amplifier IC.
If this is your problem, let me know - it can be fixed.
Check this article: http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
-Ben
Mar 16, 2009 | Samsung SyncMaster 150MP Monitor
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Awful High-pitched Noise and Echo Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Distorted sound
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Dec 03, 2007 | Televison & Video
Magnavox 40MF430B LCD TV Logo
211 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
