Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Ice maker is dripping into ice bin after water refills?
I have a an Amana DRB1801AW refrigerator that has a bottom freezer. The past three months or so I have had to put a plastic container (formerly a smaller butter container) in the back left corner of the ice bin because if I don't water drips from the ice maker down into the ice bin. It only does this right after the ice maker has dispensed and refills. I don't know if there is a simple fix, or if I need a complete new ice maker? Also, occassionally I am finding debris in the ice that looks like paper or some kind of thin lining that came off somewhere. I would appreciate any solutions so that I am not having to consistantly empty and put back the plastic container, or have my ice all matted together because of the dripping water freeziing.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
I had this problem on my refrigerator. I talked to a service tech at the local appliance dealer and here's what he said. There is a valve at the back of the refrigerator (mine is a side by side, but the basics are the same When the Ice maker goes thru it cycle, a part of that cycle is to turn on the water to fill the ice tray, then the next portion of that cycle is to turn off the water. What is happening is that the valve is getting the signal to close but due to mineral build up on the valve surface it is not able to completely shut off.
The solution is to replace the valve. This is not difficult. Turn off the water to the refrig. It's usually runs under the cabinets to the sink and you can see a plastic hose under there with a small handle you can turn to shut it off. Pull the refrig out so you can get to the back and you will see the valve. It will be connected to the same hose that is under the sink Remove and replace the valve. make sure all the little hose fittings are tight. Turn on the water under the sink and check for leaks.
Hope this helps PS you can get a new valve at most any appliance dealer.
Good luck Loringh
Posted on Oct 24, 2008
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
Ice Maker Problem
You need to check the fill tube it could be ajar. It should be going into funnel at the back, of icemaker.
If so, the valve is bad, letting the water in when its not calling for it.
Jul 12, 2010 | Amana ABB1927DE Bottom Freezer...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARB224RCW ice maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Aug 16, 2009 | Amana ARB224RCW Bottom Freezer...
Ice maker drips water
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
312 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
