Question about Sony KDL-52Z5100 LCD TV
I get horizontall lines that create dbl images on tv when first turned on problem goes away after 15 minutes any solutions
    Top Expert:
  • Sony Master
  • 75,311 Answers
Hello
The T'Con board should be suspected.
This is the picture of the supected board to your tV. But before replacing it, you must check all the connections to it for rigidness. The work is a skilled one, and if you want to do this it by yoursef, you must have thorough knoledge about how this baord works. Thie board is otherwise called as Timing Control baord, and LCD control board. The board can be bought from the authorised service center for Sony at your town. i get horizontall lines that create dbl images on  - 2_12_2012_3_58_26_pm.jpg
Posted on Feb 12, 2012
4 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: l have a sony 46" Bravia XBR TV it is also almost
All Flat TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 11, 2010
eagle338
  • 4889 Answers
SOURCE: hello,we bought our first sony
The problem going away after a while indicates that you are just another victim of capacitor plague, on the main audio video board. There are cylindrical components known as capacitors on the board which rapidly charge and discharge. If they are faulty then, it would take longer than usual to reach the optimum capacitance value. Replacing these things requires prior experience in working on PCBs, especially soldering. If you have these skills let me know and I will help you fix this. Otherwise just get me your zipcode and I will get you a list of techs in your area.
Sai.
Posted on Nov 10, 2010
bukol
  • 84 Answers
SOURCE: On power up of my Sony KDL52Z5100 I get horizontal
side fittings or lack of contacts of the logic controller interface to lcd panel.
Posted on Feb 25, 2011
My Samsung LN52A650A LCD TV is displaying green shadows and lines after being turned on for 15 minutes. This has been isolated to the display as I get the same result from DVR or DV player.
May not be a do it yourself repair, could be main board or even a loose connection at a plug inside the display panel (fatal) or outside of it.
Oct 15, 2012 | Samsung LN52A650A LCD TV
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
After 15 minutes tv turned on screen goes funny
contact the manufacturer if the problem is serious or else try loosing tje static charge from it and restart
May 07, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
Dec 11, 2008 | Hitachi SSH2442 Television
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA D52W20 tv will not turn on
mine does the same thing obviously it is a high voltage problem with the power supply or flyback transformer,we have power outages all the time more thank likely it was the colprate good luck ,my suggestion do what im doing throw it in the trash and buy a new one ,it will cost more to repair we live in a throw away society they dont make anything worth the crap any more ,tvs used to last 25 years now if your lucky 5.
Aug 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KDL-52Z5100 LCD TV Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
