Question about Kenmore Washing Machines
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
    Problem Solver:
  • 11 Answers
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
Posted on Feb 27, 2012
2 Suggested Answers
  • 2180 Answers
SOURCE: I have an older Kenmore (Whirlpool) washer......It
are you sure it's agitating?there's a motor coupling that brakes,you'll hear the motor running but it isn't doing a thing,the coupling connects the motor to the tranny. and it's made out of plastic,check this out,if it's not this then you could have a bad tranny and you can check while you're checking the coupling usually when the tranny goes there's oil from it on the floor or on the area around where the motor is.copy and paste this the video should help you out.http://www.youtube.com/watch?v=9K1KHEogf3c
Posted on Apr 17, 2011
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 series washer cycle issue
motor coupler is most likely broken. remove cabinet, remove pump from motor, then remove motor from gearcase. the coupler can be purchased at local parts supplier or ordered on line.
Jan 30, 2012 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
98 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
