Question about Lexmark X5650 AllInOne InkJet Printer
I just bought ink cartridge and says ink low on my lexmark x5650 so i just bought ink cartridges for my hp 4140 and it wont work, is this a cproblem with my computer and not my printers? 2 printers do
I have installed and uninstalled numerous times and nothin works
  • Official Brand Answer
  • 3,344 Answers
As far as the Lexmark printer is concerned, try the steps below:
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Posted on Feb 14, 2012
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: SAys replace ink cartridges.. did that but still
    The problem sometimes is that when you unpack the cartridges a little bit of residue of the packaging stays in the printhead of the cartridges. Here is a link that shows you how to clean the nozzles. http://www.bit.ly/aBjxGa
    Posted on Feb 13, 2010
    SOURCE: lexmark x5650 #36 black & 37
    to des_cunningham2001@yahoo.com
    Posted on Feb 20, 2009
    don_farr
    • 1011 Answers
    SOURCE: same problem with x5650, using a genuine lexmark cartridge
    Okay, sometimes the contacts points on the side of the cartridge are contaminated. Take a clean (pink) pencil eraser and rub the contact points. Blow any residual off of the contacts and then reinstall the contacts. Some Lexmark printer require that you use the maintenance utilities to install the cartridge and align it. It concerns me that the printer sees the cartridge when you make a copy. I strongly suspect that the cartridge is defective. Otherwise why would it fail in one mode and not the other. Have you verified the driver properties to make sure that you are not set for color only printing? Software will override the setting on the printer. Don
    Posted on Jun 11, 2009
    pineworks
    • 4041 Answers
    SOURCE: My Lexmark X5410 Printer will not recognize a refill cartridge.
    Hi there
    This is the same old story with Lexmark printers, you cant do any thing about it the chips have a small fuse inside them and soon as they emty it blows the fuse, and thats it so I beleave the only way is to buy new ink, or a diferent printer.
    Not know any fix for them myself sorry.
    Can try.
    Turn printer off. Unplug power cord and other cables. Wait 30 seconds. Plug cords and cables back in.
    Also seen this on the net.
    Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
    but yeah, best bet, never ever buy lexmark.....:)
    http://www.fixyourownprinter.com/forums/inkjet/35235
    If that doesn't work, try disabling your ink monitoring software.
    All The Best Pineworks
    Posted on Feb 21, 2010
    Testimonial: "Thanks for the quick response. I'll try these things...and not buy Lexmark again."
    yammy_alf
    • 666 Answers
    SOURCE: how to reset ink cartridge for lexmark x5650 #36
    Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one
    Posted on Mar 25, 2010
    My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
    If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
    Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
    I dont know how to change the ink cartridge on my lexmark?
    For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
    I hope this information has been helpful.
    Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
    How can I install black cartridge only without printer stopping me from printing
    The Lexmark X5650 printer requires both the black and color cartridges to be inserted in the printer to continue printing. Both cartridges must have ink in them and not empty.
    Sep 03, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    How do you close front to get ink cartridge out
    Please follow the steps below on how to change the cartridges on your Lexmark X5650 printer:
    2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
    3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
    4. Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
    Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
    We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
    It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
    Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    My lexmark x5650 ran out of ink and i replaced the cartridges and it keeps saying to replace them. they are new please help.
    I have had same problem with same model. As ink is used there are tiny internal electronic fuses which 'blow' as ink is used and cannot be reset. Sorry you need to buy original cartridge.
    ianparronline.wordpress.com
    Jan 03, 2011 | Lexmark X5650 All-in-One InkJet Printer
    I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
    Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
    Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
    Aug 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
    How to reset ink cartridge for lexmark x5650 #36 black
    Mar 25, 2010 | Lexmark X2500 All-In-One Printer
    Hi i have a lexmark x5650 printer, i have just refilled the cartriges and it wont recognise them keeps telling me to replace them, any ideas any one ? neil.
    I had same problem. I unplugged the unit, took a pink pencil lead and lightly cleaned the contacts, put the ink back in the plugged unit back in and it worked.
    May 01, 2009 | Lexmark Office Equipment & Supplies
    Lexmark X5650 AllInOne InkJet Printer Logo
    156 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
