Question about KitchenAid KEBC107 Electric Single Oven
BOTH LAMPS WENT OUT AT THE SAME TIME in my kitchen aid built-in electric convection oven KEBC107, but they are not burned out
I removed the two lightbulbs. they don't look burned out. What could happen in the wiring of the oven that would cause a failure of the interior lights?
  • Ruth Ward Feb 12, 2012
    no rodents. no rust
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
Rodents or rust
Posted on Feb 12, 2012
thaurfen
  • 623 Answers
SOURCE: kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Posted on Aug 07, 2008
aborcass
  • 2651 Answers
SOURCE: KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Posted on Dec 14, 2008
dmftrucker
  • 1922 Answers
SOURCE: How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Posted on Nov 04, 2009
SOURCE: We don't know how to turn the oven on! It is a
I fussed with all the knobs and figured it out!( wording on the knobs are gone) but we have it now! I was afraid of ruining something but ended up going for it! Thanks for following up. Lyn
Posted on Jan 14, 2010
SOURCE: we installed kitchen aid microwave convection oven
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Posted on Jul 03, 2010
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a Kitchen Aid Surpurba 1999 built in oven.
on the back of oven there is a hi limit thermal fuse /it is a one time fuse /eplace it cost about 23. to28 .00 . / you willhave to remove oven from wall ( two are best .. set it on a small table /cable may be short.. hope this helped /pls leave feed back ..
Dec 06, 2009 | Ovens
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchen aid oven not heating up
THERE IS OVENSHUTDOWN THERMAL FUSE IN THE BACK THAT WILL SHUT DOWN THE ELEMENTS. I AM LOOKING FOR THE FUSE.
Jul 20, 2008 | KitchenAid KEBC107 Electric Single Oven
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
KitchenAid KEBC107 Electric Single Oven Logo
103 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
