Question about Brother MFC-665CW All-In-One InkJet Printer
Error message when trying to scan
I keep getting the message 'check connection' when I press the scan button. never had a problem before now and cant work it out, the machine has not been moved or settings adjusted.
thanks martin
    Problem Solver:
  • 17 Answers
I have had that problem too. I had to reload my drivers to correct it.
Posted on Oct 24, 2008
When I press Scan on my Brother MFC440CN, I get an error message ''Check Connection''. I just want to scan a picture to card, which I did many times without an issue.
instead of scanning using the button on the machine try it from the computer. Brother normally gives the control center program, you can find it in all programs in the brother folder. you should be able to scan from here. if not there is probably a connection problem from the printer to the computer
Mar 24, 2010 | Office Equipment & Supplies
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Printer cartridge cradle cannot move
check if you are getting an error message as carriage jam..if you get this message connect the printer directly to the wall outlet and then check for the error message..if it still the same..perform a reset on the machine..that is you need to unplug the power chord from the back of the printer, press and hold OK and CANCEL button together while pressing these two button plug in the Power chord to the back of the printer..after you plug in the power chord do not release those two buttons, keep pressing those two buttons untill the screen is blank..once the screen is blank release the buttons and then turn on the printer..check for the message..if you are still getting any error message then it is a hardware issue..machine should be replaced..
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Can't scan documents
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Jul 31, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Cant print or scan
Hi carla;
that sounds pretty weird but you may want to try resetting it to default factory settings,just navigate through the menu if it still doesnt work, try re-installing the driver.
thanks
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
MP170 Canan Pixma scanner problem
You need to remove the Scanner software [which is different from the printer software] and re install it.
Jul 12, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Brother MFC-665CW All-In-One InkJet Printer Logo
163 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
