Question about KitchenAid KUWA244PBS Wine Cooler
LED light won't come on
The LED temperature lights won't come on to show the degrees of cooling.
My days on heat/ cool fan won't start on cool
Hi there, it's Jack at Dyson.
To run your Dyson Hot + Cool heater on fan mode, you need to turn the target temperature down to 0 degrees using either the remote, or the controls on the base. The target temperature is shown on the LED display on the front of the heater. When fan mode is activated the light around the on/off button will turn from red to blue.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
Cabrio won't re-start - heat problem?
Could be crankshaft sensor.
May 09, 2013 | Cars & Trucks
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Driving in 105 degree temp, truck quits! What happened?
If the engine won't crank with compression in the cylinders, either the head gasket has blown or something else major has happened.
You will have to get it towed to a shop.
If it cranks normally but won't start, you have to figure out if it is a fuel or ignition problem.
Did the temp gauge show it was overheating before it died ?
Jun 30, 2012 | Cars & Trucks
I have a 2 yr old dehumidifier and it runs, it just won't pull out the moisture out of the air.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(No LED screen), set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you and thanks for choosing FixYa
Sep 13, 2011 | Kenmore 938060 Humidifier
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Why would a 1994 Oldsmobile Achieva S quad 4 engine temperature gauge fluctuate between 195 & 220 degrees? The thermostat has been changed and the engine and radiator have been flushed. The normal...
either the thermostat is getting ready to fail or the temp sensor isnt working properlythese engines also leak fluid from rear side of head after getting hot so check that so may have air in system because of the blown head gasket
May 28, 2011 | 1994 Oldsmobile Achieva Special Edition
Not cooling
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
Have a good day. : )
Apr 17, 2011 | Kenmore Refrigerators
KitchenAid KUWA244PBS Wine Cooler Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
