Question about Edirol UA-4FX External Sound System
Timing and noise
I'm having two interesting (read as frustrating) problems with my UA-4FX. When I record and then playback, the sound is distorted. There are pops from the bassier notes and it sounds like the whole thing is being played on a stretched tape. As if a modulation effect were being applied. However, when I export to Wav and play it back through my soundblaster it's fine. The other problem is more serious. When I record a track, it comes out at a slightly different speed to the original. Thus, when I record subseguent tracks, I have to stretch them to fit. Also, during playback, you see the marker in Sonar getting progessively further and further behind what you're hearing. I've tried removing the drivers using the Roland removal tool and then re-installing. I've also tried re-profiling it. I've checked all the setting in Sonar options and they are as the manual says they should be. Hope someone can help, it's taking me three times as long to record my demos than it should.
  • 1 more comment
  • godiss11 Jul 09, 2008
    I am having the same problem...I did get a PCI USB PORT 2 and it is still acting up...what's next...BIG QUESTION MARK
  • stellythad Sep 24, 2008
    I have the same problem and I've loaded the program on 3 of my computers and its giving me the same problem. All I can think of it that its got to be the Device Itself.
  • bobbyjoe03 Dec 03, 2008
    mine sounds like it is being played through a leslie rotating speaker!! Wondering if this is a sample rate issue???
The different speed thing might be rellated to sample rates. if your recording the track on one sample rate and playing it at another. it will come out faster or slower
Posted on Sep 10, 2007
I own the same audio interface (UA-4FX). Ive had these similar problems but i figured it out. In regards to your first question... make sure that all of your effects are turned off. you probably have the "fx voice" and "amp drive" on. If thats not the case, the best solution is what Tubularburn wrote. To your second question... Make sure the buffer size in the software is set correctly. If youre using Sonar LE, go to "Options> Audio" and tweek the "buffer size" until the other tracks play at normal speed. If that doesnt work, then "im sorry pal, im all out of answers" I hope I helped! Even just a little. Good Luck!
Posted on Sep 03, 2007
I have a 1212 card a similar sound as you described was produced. With the 1212 you have the option (assume the UA-4FX is similar)of internal or external sync (by device eg ADAT/ S/PDIF) or multiple frequency selection 44.1K/48K etc. If any of these options are not optimized for your particlar data the described signal degredation can occure. Good luck, check your defaults and options settings. N Temp
Posted on Aug 18, 2007
That's usually caused by problems with the usb port on your computer. The best solution would be to buy an PCI USB CARD that you would use only for your UAFX4.
Posted on Aug 10, 2006
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Aug 30, 2009 | Edirol UA-4FX External Sound System
Microphone connection
you just look whether you missed out any connection while shifting ........
Aug 23, 2008 | Edirol UA-4FX External Sound System
Can't Record and Only hearing playback via laptop.
Check you XP machine for SP3, go into the sound manager and make sure that the input your using is not muted and set as default.
http://www.ejoysoft.com/images/mixer.gif
Aug 04, 2009 | Edirol UA-4FX External Sound System
Sound driver?
try going to control panel- sounds and audio devices, audio tab, and look for the default playback device.
do you have other options there, besides what it's currently set to?
this is windows xp, correct?
also, on the volume control window, try going to options in the top left, and then properties.
Make certain that you have PLAYBACK selected, not recording, and then make certain that "show the following volume controls" has all the boxes checked.
Mar 29, 2008 | Edirol UA-4FX External Sound System
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Mar 17, 2008 | Edirol UA-4FX External Sound System
Playback recordings
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Jan 17, 2008 | Edirol UA-25 External Sound System
No sound out from input
It's probably your computer, more specifically the type of application you're running it on/in. Also, when you install or fiddle with the settings, you have to be careful because it can be so confusing fixinfg them.
Dec 12, 2007 | Edirol UA-4FX External Sound System
Recording Device Not Listed
You need to install the driver accordingly, When you buy the product it comes with installation Disk. If you dont have it now still you have solution simply download the driver from the manufacturer's website
Here is the link
http://www.rolandus.com/products/productdetails.aspx?ObjectId=758&ParentId=114#
Good Luck
Aug 30, 2007 | Edirol UA-4FX External Sound System
Edirol UA-4FX External Sound System Logo
392 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
