Question about Garden
Can't start the chainsaw
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
Can't start sthil AV34 chainsaw
Do you sitll have a good spark.? Have you increased the gap too much.?
Nov 12, 2012 | Stihl Garden
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
I have a mculloch electramac em200 2.0 what mix do I use in it
I'm a little confused here. First I see a problem with Homelite 9.0 amp chainsaw, then you ask about an Electromac EM 200. Both of those are electric saws and don't require a "mix". The only thing you have to put into them is bar and chain oil.
Sep 23, 2012 | Homelite Consumer Products 9.0 Amp, 14 In....
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
L & LA screw adjustments
Just buy a new carb, it's cheaper than a new saw, or enen installing a carb kit, and your saw will run like new!
May 01, 2012 | Stihl Garden
Stihl 023 trouble starting & running
Hi, Replace with correct sparkplug. You have a bad plug replace it and you're good to go.
Mar 11, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Stihl chainsaw won't start
Put in a new sparkplug.
Jul 15, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
