Question about IBM ThinkCentre A51 PC Desktop
WHAT IS FAN FAILURE
IT TRIES TO BOOT AND THEN A FAN FAILURE ERROR AND IT SHUTS DOWN.
  • 1 more comment
  • Meme Too
    Meme Too Feb 12, 2012
    How can I tell which fan it is?
  • Meme Too
    Meme Too Feb 15, 2012
    Since the system will not boot, how do I can I make any changes to the BIOS ?
  • robert Feb 18, 2012
    the bios usually boots,on startup,go direcly 2 the bios.dont wait for it to boot.
    press either f2,f5 or del to enter bios setup
  • 131 Answers
Fan failure is when the fan that cools the machine stops working.the error always tells u which fan is not working,usually the c.p.u fan or the system fan mounted on the casing,simply check which one is not rotating and change it.or(not recommended) if it is the system fan,just go to bios settings and dissable it.hope it helps
Posted on Feb 12, 2012
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
My Acer X110 DLP Projector shuts down with a message "fan failure"
clean the fan if you have blower do air service. otherwise open it and clean the fan.
if fan totally not working then need fan replacement.
Apr 18, 2013 | Acer X110 Projector Svga Dlp 3D, Eco,...
HP M370n System fan failure will shut down in 5 seconds,
Return to the person that replaced the fan. Obviously it's not fixed.
Feb 20, 2013 | HP Pavilion Computers & Internet
My sis-in-law has a HP dv754n that just begins to boot (8 sec. and then shuts down. Shows "System Fan Failure". Volt at fan RED before and after boot failure is 5 VDC but during boot it is .12 VDC. Fan...
This is due to CPU cooler fan may faulty or not freely rotaing due to which CPU got heated up and as a precautionary measure it will shutdown the system. Need to clean the fan and apply some lubricant will resolve your problem. Replace the CPU cooler fan if required.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 22, 2010 | Computers & Internet
Computer freezes and shuts down and now says that i have fan failure as well computer will not boot up unless i go to boot screen and boot from hard drive this is a hp pavilion a1610n also it says i have a...
I would be careful if i was you because if it is a fan problem and you are starting up anyway your system can overheat and if that happens you just might be buying a new pc instead of a fan :) I use driveragent.com for all my driver needs. it searches your pc after you install it and finds any outdated or wrong drivers you might have and u can download them with a click of a button :) its a small fee but well worth it i used to have to search for hours trying to find drivers and then get a wrong 1 and continue the search
Oct 20, 2009 | HP Pavilion a1610n PC Desktop
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
IBM ThinkCentre A51 PC Desktop Logo
215 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
