2002 Yamaha YZF 600 R thunder cat Logo
Posted on Feb 12, 2012
Have a2002 yamaha 600 thundercat runs great - 2002 Yamaha YZF 600 R thunder cat
  • Michael Green Feb 12, 2012
    I am glad about that! What is your question?
5 Related Answers
Anonymous
  • Posted on May 08, 2009
SOURCE: Fork seal replacement
Did you try taking down the fork seal and cleaning out with wd/40 and a piece of 30mm film? You should always try this first. The seals rarely go bad. There's probably just a vary small rock holdeing it open and the film will dislodge it the wd is just to help things along.
Anonymous
  • 921 Answers
  • Posted on Apr 10, 2010
SOURCE: have a yamaha thundercat 600 on a 98 plate,it runs
sounds like you definitely have carb issues . got a quick cheap fix first just so you wont have to spend a lot of extra money and time..purchase some SeaFoam from Autozone pour 1/3 can into two gallons on gas and if you havent changed the fuel filter in a long time just drain it out, spray clean it up, and fill it up with some Seafoam. start it and get on it good for about10 to 15 miles, and this should clean up any varnish that could be clogging your jets. if this doesnt fix it then its time to pull the bowls off and physically look to see if the main jets are secure, not loose or fallen off into the bowl.... like when it happened to me once. but when i reinstalled that jet and cleaned up the bowls, it ran awesome infact, since i cleaned up the whole carb bank, it ran better than most 750s and i only have an 87 cbr 600 hurricane, infact it can keep up with most liter bikes, except the R-1, i havent beat that off the line yet. Mine wouldnt go near red line to save my life. Can i get a good helpful feedback if any of this has helped you, thanks, i appreciate.
sisadsl
gavin jones
  • 1508 Answers
  • Posted on May 07, 2010
SOURCE: 2001 YZF 600 R thunder cat: Yamaha yzf 600 Thundercat when under heavy load or...
Many YZF 600's have a problem with second or third gear, under heavy accelleration they will jump in and out of gear, the fix is in the gear selectors,an internal box problem.
If it is a clutch problem, ride in top gear at 100kl\hr and give the clutch lever a flick, see if it grabs or slips for a while and then takes up.
Anonymous
  • 267 Answers
  • Posted on May 11, 2010
SOURCE: Lost key for 2001 yamaha yzf 600 r thundercat, I
The site below has diagrams of the bike in exploded view form...Electrical #2 shows the steering lock also. Cheers.
http://www.boats.net/parts/search/Yamaha/Motorcycle/2001/YZF600RNC%20-%20YZF600RNC%20%28CA%20Ed.%29/parts.html
NZcavalcader
Richard
  • 83 Answers
  • Posted on Sep 11, 2010
SOURCE: what leavel should oil be
With the bike on the main stand and on level ground, the oil level should be at the top of the sightglass. Be careful to only check the level when the bike is in this position as if it not, it will alter the oil level in the sightglass. I fill the oil to this level in all my bikes.
Yamaha YZF600R. Why won't my YZF 600r start?
Diagnostics
Tachometer; Self-Diagnosis Device - Yamaha Thundercat ...
ManualsLib https://www.manualslib.com > ... > Owner's manual
Yamaha Thundercat YZF600R Manual Online: tachometer, Self-Diagnosis Device. 2. Tachometer Red Zone Tachometer The Electric Tachometer Allows The Rider To ...
Yamaha thundercat losing power
Give the bike a service including plugs and leads. Also check the intake rubbers on the carbs for air leaks.
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Fazer Brakes, Weight and Fuel Capacity
    • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
