Question about RCA P52960 52" Rear Projection Television
Bowed picture with RCA p52960
I would like to try to fix this on my own. I am a electronic tech and was wondering if you might have a fix.
Thanks
  • 4,234 Answers
This is a convergence problem and can be either bad connections at the convergence ICs or defective ICs. Try resoldering the pins first. If that fails, replace the ICs. These ICs are large, black and attached to a heatsink. It should be marked STKxxx.
Keep me posted.
Dan
Posted on Oct 24, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
I have the RCA P52960 52 in. Rear Projection Television and the picture just started bowing from the top and bottom in the form of a bowtie. I the post and was wondering if there was a way i could prepare...
my name is steven. Its wierd that i have the exact same tv and it started the same problem on the same day. I can't tell you what is wrong with it unless it is just old like mine. Thanks for posting any solutions you find. I did take the back off it and check for loose parts. Everything is intact. I vacuumed the bulbs and the screen from the inside with a brush attachment and the picture is so much more bright and crisp but the bow is still there.?
Mar 20, 2011 | Televison & Video
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
RCA P52960 Problem (bowed picture)
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Nov 20, 2008 | RCA P52960 52" Rear Projection Television
Bowed at top and bottom
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Nov 10, 2008 | RCA D52W19 52" Rear Projection Television
Bowed Picture
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Oct 06, 2008 | RCA P52960 52" Rear Projection Television
Rca 52" p52960 convergence bows
I wish it was that simple. On this chassis there are many parts that have gone bad in the past to cause this very symptom. So many in fact that there is a repair kit available that contains common failure parts p/n 250686-KIT. This is NOT a DIY project as many of the parts are small and would be hard to locate and impossible to replace by anyone not having superior soldering skills. It would not surprise me if the repair on this set would set you back about $350. If you can get a free estimate, great, but if you can swing it, you may be better off putting that money towards a new DLP rear projection NON RCA HDTV. I have had good luck with Toshiba sets for the last several years, and Consumer Reports seem to agree with me.
Mar 30, 2007 | RCA P52960 52" Rear Projection Television
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
