Question about Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic DMC-Z28 - the flash button does not call up a flash setting menu and so the flash won't turn on.
  • jeanne hall Feb 22, 2012
    Several people have said check burst. When burst off, still no flash. Also, if select flash burst , I get a message ti open flash-when it is already open.
  • jeanne hall Feb 29, 2012
    I stumbled onto the solution! The flash door was not opening completely, so with a little wiggling of the door it works. Thanks for the good suggestions. I will probably have to use these good ideas in the future.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,099 Answers
Is your Z28 set up to do burst shooting as this will stop the flash working, click on the trash button and turn off the burst shooting. Hope this helps.
Posted on Feb 19, 2012
5 Suggested Answers
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Posted on Jan 03, 2008
  • 16 Answers
SOURCE: Panasonic DMC-FX12 is frozen.
wait for the battery to run out or dismantle it
Posted on Sep 12, 2009
  • 11967 Answers
SOURCE: Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
Posted on Jan 19, 2010
SOURCE: Panasonic DMC-TZ3 goes right to 10X zoom
There is a solution to this problem discussed here http://www.fixya.com/support/t159240-buttons_stopped_working
Posted on Jul 06, 2010
Where to find histogram on z28
Make sure you have the histogram turned on in the setup menu as described on pages 24-25 of the manual: http://service.us.panasonic.com/OPERMANPDF/DMCFZ28.PDF
Jan 18, 2014 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic lumix
Press the MENU/SET button. Use the cursor keys to select the wrench icon and press MENU/SET. Use the cursor keys to select the talking-head icon and press MENU/SET. Select the desired language and press MENU/SET.
May 30, 2013 | Panasonic Lumix DMC-FH8 16 Megapixel...
Dmc gf1 flash won't work
The camera requires service, this is a nag screen and will not reset itself without being serviced.
Jan 17, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
How to turn off the flash on a panasonic dmc-fs5
Press cursor-right (marked with a lightning bolt). Use cursor-up/down to select "FORCED FLASH OFF" and press the MENU/SET button.
Jul 11, 2012 | Panasonic Lumix DMC-FS5 Digital Camera
Lumix DMC FH8
Press cursor-right on the four-way controller (it's marked with a lightning bolt). Select the last item on the menu (a lightning bolt in a circle with a slash through it) and press the MENU/SET button.
Jun 27, 2012 | Panasonic Lumix DMC-FH8 16 Megapixel...
How do i turn off my flash on my panasonic dmc-fh27?
Touch [MENU] to bring up the menu. Touch [REC] to enter the recording menu. Touch [FLASH] to enter the flash menu. To turn the flash off, select "Forced Flash: OFF" (lightning bolt in a circle with a slash through it).
The flash menu is described on page 66 of the advanced manual.
Feb 25, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
How to turn the flash off DMC-TZ1 camera?
On the menu set button at the bottom right at the back of the camera, if you press the right hand side of this you can change the way the flash operates from auto, auto/red-eye reduction, forced on... and the final one would be forced off. You can download the manual from http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_222458 enter DMC-TZ1 into the enter model box and then download the operating instructions and on page 40 it will show you how to do it.
Jan 25, 2012 | Panasonic Cameras
How to turn on flash?
Ok you should have a button on there says menu or settings,,Anyways once you acces menu you should be able to do the changes to want,,and other menu options,,should be on the back side one of those buttons,,not the one on top .thanks and good luck,,also u can check panasonic website,,for help and download free manual if you dont have one.
Nov 18, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
Multiple copies of pictures
Yes may be, there was a same query here;
Check the settings for "Burst Mode" in your Cam, it will be under main settings menu. Turn it off, if the problem prevails better backup all the pics/videos and then Reset the Camera.
If helpfull, kindly do Rank.
Regards,
Waqar
Jul 17, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
439 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
