Question about Eureka Vacuums
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
    Problem Solver:
  • 10 Answers
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Posted on Oct 24, 2008
  • angelicvicto Oct 01, 2010
    I did that and the brush still doesn't spin right on mine, the belt actually still seems a little lose, we replaced the bag and filters too. I have two dogs both german shephards, i need it to pick up their hair (which my dogs seem to have an endless amount of) am I using it wrong?
2 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Posted on Dec 09, 2009
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
I have a eureka 4D boss vacuum that won't go into barefloor mode and has no suction in carpet mode
turn the beater head over and see if something is stuck ours was totally plugged with stuff till I cleaned it last week for wife .
Dec 24, 2015 | Eureka Vacuums
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it...
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Oct 01, 2010 | Eureka Vacuums
Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Jan 24, 2010 | Vacuums
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
No suction on my eureka boss smart vac. The belt is fine and the roller moves. I just changed the bag but no dice. any insight?
I know this is an old question but this is a good vac and maybe I can help somebody else some day, wish I'd figured this out a couple months ago when this problem first started. :} Anywho, this is another option from an amateur; I don't know the right terms but here goes: Right below the yellow flow knob (Floor/Hose) are the tops of two hoses, one to floor beater, one leading to hose. There is a sort of black clip holding these in place. Open it up, it hinges toward the front of the vacuum. On the back of the vacuum to the right of the lower cord wrap is a gray screw-looking thing, with little pix of locks imprinted above - one locked, one unlocked. Turn the screw toward unlock. Take the top of the black tube that leads to the hose and maneuver it out of the hole it's in, and you may find your clog in the top there. I found just a handful of dog hair, leaves and sticks stuffed in that tube but it was dense enough to stop flow to the hose. Removing it fixed the problem completely.
Aug 15, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Carpet height selector doesn't work.
You have a bad belt. It may not be broke but it's so loose that it isn't turning the brush roller when a little resistance is applied to it. That belt is cheap and it's routine maintenance to change it about every 6 months. You will notice a big difference when you put a new one on.
Nov 22, 2008 | Vacuums
Vacuums Logo
931 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
