Question about Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr
Firex 120-1182 smoke alarm - Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr
  • John White
    John White May 02, 2016
    This vlog contains useful information for those with older FireX smoke alarms that require updating/upgrading:http://kiddefirex.blogspot.com/
    New Friend:
On amazon you can find it easily. take a look here
Amazon com Firex 120 1182 . cheers
Posted on Nov 22, 2014
Firex smoke alarm won't quit beeping?
After you change the battery it will continue to beep every minute or so for about 20 minutes then return to normal operation..
Mar 17, 2017 | Home
I have two firex smoke and carbon dectectors, and 3 smoke detectors in bedrooms.
do they beep three times, pause then beep three times again? if so, they are going into alarm. since they all ring together, the only way to tell which one is causing the problem is to look for one where the leds are different than the others. If your detectors are more than 10 years old, replace them all as required by the national fire code (NFPA72). If they are only doing single chirps, that is usually an indication of a low battery...perhaps the breaker for the circuit has tripped causing them to run on battery only. good luck
Nov 27, 2015 | Kidde Firex 21007624 Ac Carbon Monoxide...
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
I am looking for a replacement smoke detector Firex 120 1182. Can you assist?
Everything I can find indicates that this unit has been discontinued, but there are a variety of recommended replacements. If your devices are more than 10 years old you need to replace all of them by code (NFPA72); hope this helps.
Feb 25, 2015 | Home
Why does kidde smoke alarm red button(tedt weekly) keep blinking
Most smoke alarms have some indicators that mean different things, depending on the model number. To find the model number, turn the unit counterclockwise about 1/8 of a turn and pull down from the base. Kidde's website has user manuals for their products. Go to Kidde Product Documents firex smoke alarm manual to find the manual for your model.
Oct 02, 2014 | Home
Firex i4618
This is a smoke alarm and is not intended to be connected to your alarm system. While there is often a way to connect a listed relay for that purpose, connecting your smoke alarms to your alarm system can cause as many problems as not. Because the devices are not made to interface directly with the alarm system, proper supervision is usually not achievable. Loss of power might even cause false alarms. Some alarm companies even have policies in place forbidding such connections. Additionally, in the event of a false alarm you will need to call an electrician because most alarm technicians are not licensed to work on high voltage smokes. As a rule, you're much better off to add a few LV or RF smoke detectors to your alarm system for monitoring than to try to interface smoke alarms. Hope this was helpful.
Feb 01, 2012 | Kidde Firex I4618/4618 Ac/dc Ionization...
My new Firex 21007581 with a new battery keeps chirping. What is the problem and how do I fix it? Thanks Sal
He said it had a new battery so he already did that and why would you service a $12 throw away smoke alarm? This FIREX he identified is the 4618 and will also chirp while the LED light blinks, chirp is about 30 seconds after blink if the unit itself needs to be replaced because there is something wrong with it as opposed to a different chirp pattern for battieries. If still unerwarrantee FIREX will replace otherwise go buy a new one.
Sep 07, 2011 | Kidde 21007581 120v Firex 4618 Pro Basic...
Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 18, 2010 | First Alert SA302 Dual System Smoke...
Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr Logo
1,933 people viewed this question
Top Kidde Home Experts
Paul Bade
Are you a Kidde Home Expert? Answer questions, earn points and help others
