Question about Car Audio & Video
Installing boss ba 2200 amplifier - Car Audio & Video
What's the watts for a boss audio systems BA-1200
Here is the manual with all the specs for the BASS1200 10" Low Profile Amplified Subwoofer
http://www.bossaudio.com/manual/index.php?dir=&file=BASS1200_EN_UM.PDF
Sep 16, 2015 | Boss Car Audio & Video
Serial number for BOSS car amp its a Chaos C700 2
YEAH THATS A DECENT AMPLIFIER AS LONG AS YOUR SUBS DONT REQUIRE ALOT OF POWER YOU SHOULD BE FINE
Feb 12, 2010 | Boss C700 Car Audio Amplifier
Hi looking for a manual for a boss ba-1000 car amp
You can contact boss electronics or the amp retail store.. Most boss amps are sold at flea markets so they may not have direct access to the Manufacture. look at your amp and see if there is an 800 on it if not contact the place you bouht it for a phone #
Nov 02, 2009 | Car Audio & Video
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Boss car amps
boss sucksss if you get one throw it up on craigslist and sell it to some ****** then buy something with higher rms.
no offense but boss is the ultimate piece of ****.
Mar 30, 2009 | Boss AUDIO SYSTEMS CX1800 Car Audio...
Having trouble with BOSS BA-2900 car amp, anyone knowing anything about...
There's your problem. Boss is garbage, you get what you pay for when it comes to car audio.
Jan 05, 2009 | Car Audio & Video
Boss BA-2900 car amp doesnt produce any sound
i have come across a similar problem before. if you are using the ceramic (glass, clear) fuses the solder in the end caps sometimes melts. you will not see the fuse blown, but the fuse may still be bad. try a new fuse to see if that works. also make sure no single stray strands of wire from a positive or negative wire are touching on the terminals on the amp. i hope this helps. ill keep thinking of other things in the meantime
Jan 05, 2009 | Boss Car Audio & Video
Wiring up amp/installing amp
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Apr 04, 2008 | Car Audio & Video
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
