We have just bought a GMC MX555 Garden shredder (second hand) - the on/off switch has become detached from its wiring - we hoped that you can instruct us with which wire goes to which connection on the switch. Marisue 12/02/2012
mixmaster
  • 626 Answers
SOURCE: wiring diagram
Manual is here; http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-4021~3021~306~2092%20(EN).pdf Page 23 has the wiring info. Best of Luck.
Posted on Sep 26, 2007
Testimonial: "Thank you very much for your help, job now done."
mixmaster
  • 626 Answers
Users Manual is here;
KDC-4021 MANUAL
Wiring info is on Page 23.
Best of Luck.
Posted on Nov 11, 2007
  • 3 Answers
SOURCE: alpine 3523 no instructions or wiring
I know this is a little late but I have one and the hookup is very easy, On the right side of the amp there is a six pin plug. Above it it says BATT REMOTE GND. The two pins below BATT are the battery (V+). The pin below REMOTE is the (V+) switched turn on. The two pins below GND are the ground. The rest is simple. Two RCA inputs. The switch to select MONO(R), STEREO, or MONO(L) works as explained. If you want stereo, put the switch in the middle and supply two inputs and two speakers. The MONO(R) and MONO(L) are to select a single input that will supply a single (bridged) output. Connect two speakers and they will supply the same source or connect one speaker to the outer speaker terminals for higher power output. The variable or fixed switch just bypasses the GAIN CONTROL knobs(used for Alpine's 8 pin DIN plug on unit, for older EQ's and head units.
Posted on Oct 18, 2008
  • 71 Answers
SOURCE: Brake Light switch removal GMC PC
just unplug and unscrew its threaded like a bolt
Posted on Mar 28, 2009
SOURCE: wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Posted on Jul 16, 2009
Does the Macallister Garden Shredder need the position of the blue wheel on the side changed for fine shredding?
being second hand , I suspect that the cutters are blunt
not much to do about that
if was sold 2nd hand then you can expect that it was worn out
Jun 14, 2016 | Shredder Office Equipment & Supplies
Why does the garden sheader motor swithes off after a few seconds
Not sure, but most shredders will shutoff if the paper underneath is bunching up in the thrash can, see if thats the problem.
Aug 11, 2014 | Office Equipment & Supplies
Need to change dimmer switch in my 1999 gmc safari
The headlight dimmer not the dash dimmer? If so here are the instructions
  • 1Remove the steering wheel shroud, using a Phillips-head screwdriver.
  • 2Locate the two screws holding in the multiswitch. Take these screws out with the Phillips-head screwdriver. You may have to adjust the tilt on the steering wheel to access the screws.
    • 3Pull the switch out slowly by hand. This will expose the wiring harness that is attached to the switch. Separate the wires from the harness by prying the tab up with your fingers and pulling them apart. There will be one large harness and two smaller harnesses to detach.
    • 4Separate the switch from the steering console by pulling it out with your hands. Pull slowly to prevent the switch from catching on other components.
    Installation
    • 5Attach the wires to the new switch. The new wires should be spliced to fit your vehicle schematics. Simply push the wires into the appropriate harness. They will click when they are seated correctly.
    • 6Position the switch to the steering column. Start the screws to ensure it fits correctly.
    • 7Tighten the screws with the screwdriver.
    • 8Turn the ignition key in your Safari to the "Run" position, but do not crank the vehicle. Test the switch to ensure the turn signals are working correctly. Test the windshield wipers as well as the dimmer switch.
    • 9Tighten the steering shroud back around the steering console, using the screwdriver.
    Sep 19, 2012 | 1999 GMC Safari
    Today I bought a Fellowes shredder #W10C. The instructions show an on-off button on the back of the shredder. There is not one therefore the machine does not work
    the machine has switch on front that has an I O R
    I think there is also a lock out switch. the machine will do nothing until you put the switch on the I position and insert a piece of paper, then is will start up. O is the off position and R is for reverse.
    good luck with this.
    Jul 21, 2012 | Fellowes Office Equipment & Supplies
    The shredder was paper jammed
    Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
    Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
    Follow instructions to oil your shredder;
    To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
    Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
    1. Depress and hold the reverse button down.
    2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
    3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
    4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
    5. Repeat steps three and four above at least three time.
    Regards.
    Apr 20, 2011 | Geha Primo 1400 Shredder
    I bought a second hand 5 way microscope for my grandson. The batteries had leaked inside. I cleaned off the leakage using baking soda and then alcohol. after it dried I put in fresh batteries but it won't...
    Baking soda will nuetralize the chemicals, but will not clean the contacts sufficiently. You will have to use a fine grit emory cloth or knifeblade, or similar abrasive material, to scrape the compromised contacts, until you get to fresh, uncorroded metal underneath. This will usually restore the unit, and make it operational.
    Also check that the switch is good for the light, since they can become oxidized also.
    If you're good with a voltmeter, you can ohm out the wiring, or troubleshoot it to find the problem.
    If it's a switch, it's usually a swivelling metal contact, so make sure it's clean and making a good connection.
    Good luck, and hope this helps.
    Mar 25, 2011 | Tasco Science & Laboratory
    I need step by step instructions on replacing a fuel filter in a 1998 gmc 6.5 turbo diesel please
    I got this from Haynes Diesel Engine Repair Manual. I bought it for my 6.2.
    1. Remove the fuel filler cap and air cleaner assembly.
    2. On filters without an air bleed screw, place a rag under the filter to soak up fuel and detach the lower clip FIRST to release pressure and then the top clip. They pop off with a screwdriver.
    3. On filters with an air bleed screw (top passenger side) drain fuel from the filter by opening the screw first and the engine water drain valve (engine front near thermostat) if it has one. Detach the clips and remove filter.
    4.Make sure the seating surface is clean and place new filter in position. On non-air bleed filters put the upper clip on FIRST. On air bleed filters secure both clips, then close the valve and attach a piece of hose to the bleed port into a pail.
    5. Air must be purged BEFORE start up, so disconnect the pink wire from the top of the injector pump and crank the engine in 10 second cycles with a 30 second wait time until clear bubble-free fuel comes out the lower fitting or air bleed. Connect the lower clip on the non-air bleed , close the bleed hose and reconnect the pink wire.
    6. Start the engine and let it idle for several minutes to purge any remaining air and check for leaks.
    Hope this helps.
    Jan 31, 2011 | 1993 GMC Sierra C3500
    My fellows jbo1 jamed and then stopped running is there a reset buton?
    Chances are it's over heated.
    Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
    From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
    Dec 15, 2010 | Fellowes Office Equipment & Supplies
    I have a Ryobi ESR 2240 garden shredder and need to put a new switch on. I didn't note the connections when I removed the old one. Can you tell me which wires go to which terminals?
    There are 4 terminals on the back of the switch, numbered 13 / 23 and 14 / 24. Terminal 24 is the neutral wire from the cut off switch. Terminal 14 is the live wire from the mains. Terminal 13 is the brown live wire which comes out of the choc block with a black wire. Terminal 23 is the other brown wire that comes from the choc block.
    May 26, 2010 | Heavy Machinery
    Mar 21, 2009 | 1995 GMC Sierra
    164 people viewed this question
    k24674
