Question about Car Audio & Video
Shorted Out a JL Audio E4300 Amp
While re-installing the speaker wires in my vehicle I shortage out my JL Audio E4300 amp and now the protection light is on and won't go off. I accidently ran a screw through the middle of one of my speaker wires and when I turned up the music the E4300 cut off and I can't get the protection light to go off. I have completely removed all wires and then only plugged up power and ground - still no luck. Is the amp fried? Can I fix it in any way?
  • 356 Answers
The screw through the speaker wire caused a dead short and turninged it up loud, you may have fried the capacitors on the output side of the amp circuit. It is easy to tell if you open the amp up, but do so with it disconnected and out of the car. The tops of the caps may be split or bulged. It is worth fixing in my opinion.
Posted on Feb 16, 2012
What can I do when my amp goes into protect mode? A6450 class a/b Jl audio
Check your speakers wiring to make sure they are not touching. This will make your amp go in protection mode.
Mar 10, 2015 | Jl Audio Car Audio & Video
Amp turns on but no output
1 make sure its hocked up properly .2 see i if the protection comes on.. with out the speaker wires hocked up if it does the u have a bad amp.3 if the amp protection light is off with out the speaker being hocked up and after hocking up the speaker it comes on the u have bad wiring to your speaker or a bad speaker
Jun 14, 2013 | Jl Audio 500/1 Car Audio Amplifier
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Amp comes on then shuts down JL 500/1
what do you have hooked up to it? Subs, Speaker, so on. it sounds like it is going into protection because of improper wiring... or it was improperly wired. if it is malfunctioning you need to take it to an authorized JL audio dealer. It's going to cost some cash unless you have a warranty on it and it was installed by a liscensed technician.
May 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
When i turn on the key the protect light comes on and it makes a funny sound
Something is shorted most likely. Check the wiring to your speakers. Check especially for stray strands of wire where the speaker wire connects at the amp and speakers.
Nov 16, 2009 | Jl Audio E6450 Car Audio Amplifier
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
Problem with amp...
In virtually all instances where the protection light is illuminated, the amplifier has gone into protection because the output transistors are shorted. To eliminate external wiring problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
If it does have blown outputs, it's is likely due to the speaker wires shorting together when the woofer was out of the vehicle.
Dec 29, 2007 | Jensen XA4150 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
JL 500/1
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
Oct 18, 2007 | Jl Audio 300/4 Car Audio Amplifier
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
