Question about ASUS A6U Notebook
Asus u5f series keyboard problem
Dear all,
My notebook has a few keys not responding properly, "H, h, U, u, 0, ), F12". Sometimes they works perfectly, sometimes not.
Is there anyone who can solve this problem ?
Many tks.
Mike
  • 849 Answers
If you are not techically sound, then you should contact to a qualified technician for cleanup the keyboard contacts.
Posted on Nov 05, 2008
I have an asus eeepc seashell series and i turned it on and it says reboot and select proper boot device and i dont know what that means or how to do it
Power laptop, when asus logo is seen, look down bottom right, press F12 or the number assigned for your model, use the arrows up down keys on the laptop keyboard, highlight hard drive and press enter, this will set the boot order for your hardware to start.
Jun 15, 2012 | ASUS Eee PC Seashell 1005HAMU17PI PC...
The fn hotkeys f3 to f12 are not working.
It could be a key problem or a connection problem, cleaning the contacts helps by using contact cleaner. You can also remove the keyboard and clean the ribbon contacts and place it back again. At times it works but if not you need to replace your keyboard.
May 27, 2011 | ASUS Eee PC 1000HE Netbook
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system restore..to do system restore try this link..see the use system restore topic
Oct 02, 2010 | Toshiba NB205-N210 Netbook
My keyboard sucks
You will need to replace the keyboard.
You can buy one here and install it yourself with a srewdriver.
http://www.amazon.com/Keyboard-Asus-EEEPC-EEE-Black/dp/B0032GVEDG
Power down the 901 and remove the battery pack.
There are 3 retainers along the top edge of the keyboard near the F1, F6 and F12 keys. Slide a thin blade or screwdriver between the case and the keyboard frame next to a retainer and lever the frame over the retainer. Repeating this for the remaining 2 retainers will free the top edge of the keyboard. Lift the top edge of keyboard and slide it towards the display to release the 2 catches holding the bottom edge keyboard in place.
Carefully move the keyboard to reveal the connector on the motherboard for the keyboard's flexi cable. Use a small screwdriver to release the black retaining clip on the connector by sliding one end of the clip at a time away from the connector a few mm. The flexi cable should easily slide free allowing you to remove the keyboard completely.
Reverse the procedure to replace the keyboard.
Hope this helps!
Jul 24, 2010 | ASUS Eee PC 900 Notebook
Keyboard responds intermitantly
under each key there is a plastic type small button with a rubber mounted on it if it is moved from its position slightly this happens.need to get opened and cleaned and readjusted properly to make it work properly. feel free for further assistance. thanks.
Jan 04, 2009 | HP Pavilion dv6000z Notebook
ASUS A8J notebook keyboard input error
Check tomake sure the Function button is not activated -this could be the problem.
Feb 21, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard does not work
don't think this is caused by the game install shut down the pc and remove the battery and charger for a few minutes. Boot it and try again try connection an external keyboard
Sep 11, 2007 | Gateway 2520915 Keyboard
ASUS A6U Notebook Logo
364 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
