Question about Cameras
Backing up a
How do you back up the hdd?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You didn't specify the make and model of your camera, so I'm going to assume it uses a memory card of some type.
The best way to back up the camera's internal memory is to copy the pictures to a computer's hard drive, then back up the computer's hard drive your usual way.
Posted on Feb 12, 2012
Wind top AE1900 AIO MS-6638. how to replace hard disk
To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
Oct 13, 2011 | Office Equipment & Supplies
How can I replace my defective HDD on my Sony laptop model VGN-SR210J
remove the screws for HDD from the back side of laptop... remove the screws that holds the HDD...
replace the old HDD with new HDD...
place the screws back and close the lid...
Feb 06, 2011 | Sony VAIO VGN-SR210J/B 13.3-Inch Laptop...
My nba 2k11 game wont work
Your game is probably damaged or dirty if it says open tray take out the game,turn off your console,take the HDD off the top of your 360,turn oun your console,put your HDD back on top then put in the game and repeat thin process.If this is not the case then take game out turn off 360 take HDD off turn back on put HDD back on and put the game back in,or if you blow the across the refletive side of the disc because when putting the disc in the tray it can easly pickup dust particles.
Jan 16, 2011 | Microsoft Xbox 360 Console
Hdd password frozen on laptop These both worked. Thanks much to Eddie333 and howarthjd2. What I ended up doing was this: Note- I was not replacing the HDD, merely trying to reinstall WindowsXP, which...
if you download the sata drivers from the toshiba website for your specific laptop and then extract them and get nlite ( www.nliteos.com and slipstream the drivers into the xp disc you can then re install xp and it should allow you to boot.
As for the hard drive frozen password that should be in the bios on the hard drive that you set it for so it should remember it
if not you may have to contact toshiba and they should have a back door password that they can produce once you give them the asset tag ( serial number of the laptop ) and once you enter that it should resolve the hard drive frozen issue.
Had a hard drive frozen at a school once and had to call dell ( as it was a dell laptop obviously ) and gave them the serial number and they created a back door password for me - jobs a good one :D
Apr 29, 2009 | Toshiba Satellite A205-S5804 Notebook
I turned of my eMac without turning of the 3.5 HDD external enclosure and now the icon does not pop up on my desk top? How do I get the icon back
Boot eMac
Unplug the DATA cable for the external HDD where it enters the computer.
recycle power to external HDD
plug the data cable for the external HDD back into the eMac.
Icon should appear after a small delay.
IF NOT -- Reboot eMac.
Mar 10, 2009 | BYTECC Aluminium 3.5" HDD Smart Drive...
How can install hdd in laser printer
The HDD in this machine is installed in the back of the machine. Power machine off and and remove the two thumb screws on the back cover. The HDD actually is installed on the cover that you remove. You need to get Xerox's HDD kit though to do it. It comes with all the neccessary connections and cables. Its part number is 121K44411.
Hope this helps.
Dec 03, 2008 | Xerox Phaser 8550DX Laser Printer
Archos 605 wifi recovery code 107
Carbon Adsorption Solvent Recovery Systems
Oct 21, 2008 | Archos 605 WiFi Digital Media Player
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
Hdd error
Hai,
Your hard disk is having some kind of mechanical problem.
Best solution for this is when it boots up, back up your important documents to a pen drive or CD and go for new HDD.
good luck
Rabby
Jun 16, 2008 | Toshiba Satellite Pro 6000 Notebook
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
