Question about Nokia 6020 Cellular Phone
How to fix restore settings - Nokia 6020 Cellular Phone
  • phebe bosque Feb 12, 2012
    how to uncorrupt my phone?
    pls help me
    Sergeant:
  • Nokia Expert
  • 220 Answers
*#7780#
Posted on Feb 12, 2012
My acer tablet screen froze after I accidentally deleted apps that I don't need. How can I fix other than buying a new tablet
First, try rebooting. If that doesn't fix it you may consider restoring the device to the original factory settings. A word of warning...restoring to factory settings will take the tablet back to the way it was when originally purchased. All passwords, updates, music, photos, videos, audio recordings, apps and so on added after it was purchased will be deleted. So don't do this if you are concerned about losing the aforementioned data and files. To do a factory reset go to settings and look for a restore option. It may be under something like system restore, device settings, back up and restore or something similar. Once you find it, it should warn you that your device will be restored to factory settings and that all post factory apps, passwords, data and files will be deleted. If you still want to restore your device follow the instructions. You will then have to set everything up from scratch as if it was just purchased. I did this with a Kindle Fire. After the factory restore I reinstalled my apps, added all my accounts (email and so on), downloaded all my books, music, etcetera, and it has worked great since.
Jun 18, 2017 | Acer Tablets & eReaders
Need to restore windows vista back to manufactures settings
If you download and install windows updates and updated drivers from Toshiba that may fix your problem otherwise press F8 just before it starts to boot and choose restore if the restore partition is still intact on the hdd.
Feb 20, 2014 | Toshiba Qosmio Computers & Internet
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
I need to restore my vista to factory setting as I have a virus on my computer so I am using my laptop to try and find out how to complete this procedure ;please could you help me . regards Jackie
System restore is a tool that allows you to take settings for windows back a few days or even weeks to a time when your computer worked better. This has worked to fix problems when antivirus tools couldn't fix a problem.
To use system restore click the START BUTTON, choose ALL PROGRAMS.
Click the ACCESSORIES folder, and choose SYSTEM TOOLS.
Choose SYSTEM RESTORE, after a brief delay as settings are checked you will be given the option to revert your computer to a date when it worked better.
Once you've selected the date when you're sure it worked better system restore will adjust settings, reboot the computer, and adjust settings again on startup. The process takes about 30 minutes.
If you have selected a date that's not far enough back you can repeat this process with an earlier date.
May 15, 2011 | Computers & Internet
I want nokia 3600 slide phone format number
there are two method of doing hard format on most of the nokia devices.
1.MANUALLY
1. go to menu and search for setting option.
2.enter in setting menu and search for restore factory setting option.
3. when you press on restore factory setting it will ask you for code enter 12345 the default code.
now you are done.
2.USIN
G CODE
DIAL *#73
70# on main screen.a menu will pop up like restoring all data press ok enter 12345 default code.you are done now.
TO RESTORE SETTINGS ONLY.
USE THE CODE *#7780#
always use fixya to fix every thing
Feb 15, 2011 | Nokia 3600 slide Cellular Phone
On the screen is a hour glass ad all it dose is turn.how can i fix that
Your Blackberry probably just needs to be restored to factory settings. The steps you need to take to restore the blackberry firmware are described at : Restore Blackberry to factory settings.
Apr 20, 2010 | Sprint BlackBerry 8703e Phone
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
LLumix DMC-FX01
hi sir..
to fix the problem please restore the factory setting..
it will be in setting> restore factory setting> then restart..it fix the problem.. thank's sir.. please rate it.
Sep 03, 2008 | Panasonic Lumix DMC-FX1 Digital Camera
How do I reboot or restart psp to original or factory settings
Restore Default Settings
From the XMB menu, go to [Settings] > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings.
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Nokia 6020 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
