Question about Acer 90.00012.30B Computer Speakers
Sound problems i have no sound on my acer computer i checked the audio on my computer it seems to be on but no sound still
  • imanoTTer Dec 08, 2008
    My speakers work Only when I test them in the control panel. So, I know the speakers work, I don't know why I have no sound for playing CD's, or watching videos online, or playing card games. No sound when I turn on the computer, no error dings... that may be a blessing. But I went to control panel, clicked on sound, tested the speakers, and they both work. I can't get them to spontaneously play when they're supposed to.
  • jtdhbtm Mar 11, 2009
    I have the very same problem. My computer crashed (blue-screened) , since then I have no sound. The speakers work when I run a test on them, but not when I want to play music( off i-tunes that I downloaded for my iphone), and no sounds for anything related to the use of my computer.
    Problem Solver:
  • 4 Answers
Umm have contacked the compont
Posted on Oct 24, 2008
  • Eric Carrillo Oct 27, 2008
    have tou called the compony
I plugged the speaker but still i cannot hear any sound.
check your control panel>sound and devices>audio, you must see an option that state your sound device, if you don't have that option their might probably a problem with your sound driver.
Sep 09, 2011 | Acer 90.00012.30B Computer Speakers
I am unable to get any sound through the speakers although they appear to be OK. Do I need to download a connection again? I cannot get any sound from any source, I tunes, Email attachments, videos...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 14, 2011 | Acer (90.18612.36B) Computer Speakers
We dont have any sound in our acer computer
check sound properties in control panel->if greyed out u need to install the sound drivers.
If not check whetehr speakers are connected to right color port behind pc .also check in ctrl panel->sound and audio devices whether the right output device(speaker) is selected or not?
regards
abhilash
Sep 16, 2010 | Acer 90.00012.30B Computer Speakers
Very bad echo, on my NEW Acer laptop 8730G-6945
I had this problem for months - I finally figured it out on my own...
Go to your RealTek HD Audio Manager (this is either a red speaker icon in the bottom right hand corner or if you go to 'control panel, sounds speak and audio devices, realtek hd sound effect manager)
once you have the window open, under 'sound effect, go to environment and to the right of the drop down menu, click 'RESET'.
After months of trying to fix this issue, this fixed it for me!!! I hope it does for you too!
Feb 15, 2010 | Acer 90.00012.30B Computer Speakers
I have an echo that suddenly appeared in my Acer Laptop sound. It puts an echo on all sound (music, movies, etc.). It might have happened when my son downloaded music, or with him simply mucking about in...
Dec 30, 2009 | Acer 90.00012.30B Computer Speakers
The sound is to low it seems that the speaker
check your Sound audio option in Control Panel....
check your audio jacks and cables for any cable faults...
check the volume control
Dec 10, 2009 | Philips SBP1100/37 Portable Speaker System...
Audio is distorted
try to reinstall the driver that all and hope this will work fine.
Oct 07, 2009 | Audio Players & Recorders
Error code 88780078
Check these things:
1) Click the Start menu button > Click Control Panel (Or Settings > Control Panel), Click Sounds and Audio Devices > Click the Audio Tab: Do you have a Default Device listed under Sound Playback and MIDI playback?
This also may say "Available Device" which you could change to the other option in the drop-down menu as a test. If you change it, restart first, and then attempt sound.
2) Press and hold "Windows Logo" Key + Press the "Pause Break" key on your keyboard > Click Hardware tab > Click Device Manager:
Do you have a multimedia driver configured and installed with no problems. (Problems being exclamation points or with a red "x")?
There are many other issues that can cause this. Please check these first and let us know.
Apr 17, 2009 | Acer AOpen SoundBox 300 Computer Speakers
Speakers not working, but cables all plugged in...
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Jun 21, 2006 | Dell A215 Computer Speakers
293 people viewed this question
Top Acer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
