SOURCE: 1997 chervolet venture radio reset codes
I had the same problem with a 97 transport. Here is a couple solution to your locked radio problem. This is assuming you have the ACDelco radio original to the vehicle. One way is to allow the vehicle to warm for an hour. After warming the vehicle press either the 1/2 or 3/4 or 5/6 buttons together. In two on the sequences, a three digit code will come up. Write these codes down. I called the original seller of the vehicle, (if known) or a GM dealer. Speak with the parts or service department. They do not have the 4 digit code to unlock the stereo, though they can make a call to ACDelco and get the code. The other way is to take it to a dealer and have them erase the code, which is approx. 30-50 dollar depending on the service station. Hope this helps.
SOURCE: is there a replacemnet radio for 2005 malibu with
give these guys a try and maybe they can help you its www.schramauto.com and 1-800-292-1032 Schram auto parts they deal with GM parts only
SOURCE: dont know how to reset or bypass gm theft system car is not starting .It tries and quits.
this is one way to reset it :
first make sure the battery is fully charged , then do the following:
key in the ignition but do not crank the motor, just leave it at the
ignition mode for ten minutes ,then turn it off POSITION for 5 seconds then REPEAT again 2 more times. at the 3 rd time youre gonna notice the ANTI THEFT light on dash to blink. when doing the last step , remove key , inserted again and turn on motor , good luck , AJ
SOURCE: I changed the battery on a 97 chev malibu and
hey did you try the year of your vehicle I have the same car and had the same problem the code was : 1997 hope it works for u!! ash
