Question about Seagate FreeAgent Computers & Internet
I NEDD AN E157925 BOARD FOR A SEAGATE
THE PLUG IN EMERGED DISABLING THE BOARD WHERE TO BUY IT?
Where can i buy a seagate external drive circuit board to replace one I "fried" by overvaulting my current one?
Spare PCBs aren't usually avaiable as such. Unless something simple like a polyfuse blew on the board, then the original is probably toast. Your next option would be to obtain an identical drive and perform a transplant. But it will have to be identical - possibly down to the software revision.: (You may still have problems as tables of bad blocks are maintained by the controller)
Nov 28, 2016 | Seagate Computers & Internet
Accidentally i plug different adapter. It is not working now.
you might have fried the voltage regulator on the board chances are the hdd is okay its a sata or ide open housing and go to tiger direct and buy whichever style hdd it is adapter to usb i.e ide to usb or sata to usb ot a new enclosure like nexstar cx once you got it hooked up if its still good you can get to your files
Mar 26, 2014 | Seagate 160GB 3.5" External USB Drive 160...
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
The logic board of my seagate st3500418as was fried. can i buy and replace its logic board for me to recover the files inside that harddrive?..also, where can i buy that board? can i use a board with...
https://www.seagate.com/consumer/
the above link will take you to the best support. Personally I might acquire the same model and swap out the hard drive but Seagate offers a wide variety of data recovery as well. Some drives came with warrantied data recovery
Feb 14, 2018 | Computers & Internet
Where can i purchase a replacement board for my seagate barracuda 7200.12? the usb slot has snapped off the board.
This is an internal hard rive and therefore does not have a USB slot. I assume you are referring to the SATA connector.
The control board is not an item that can be bought separately. You may be able to buy a used drive on ebay.
Try and find someone who can solder the connector back on for you.
Feb 22, 2011 | Seagate Computers & Internet
Hi I have a seagate raptor 3.5" V2R1 external hard drive and the socket on the board that you plug the cable ( USB on one end) into from your PC has come of the main board...can the board be...
Here's your solution, I had the same problem. Purchase Thermaltake Black Widow PC Gaming Hard Drive eSata + USB Docking Station (part number: ST0005U). I got mine at Best Buy for $55, but I'm sure you can find it online for much less. Good luck - trust me this works..... oh and by the way, dont buy a SATA-to-USB cable because your USB port on your PC does not provide enough power to the hard drive and you won't be able to access your drive.
Dec 06, 2010 | Seagate Computers & Internet
E157925 inverter board won't light up lcd screen What are the usual problem components?
Typical failures in DELL LCD monitors are: cold solder joints, bad fuse (still has continuity with high resistance), shorted MOSFET/B-POLAR transistors, bad caps, lamps assmblies.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
189 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
