Question about Comstock-Castle Kitchen Appliances - Others
Where do i lite the pilot for castle deep fryer model #10hf
Model #10hf
SOURCE: WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Posted on Jan 25, 2008
  • 77 Answers
SOURCE: DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Posted on Feb 19, 2008
  • 3 Answers
SOURCE: Bravetti Deep Fryer-Model EP65
I have Bravetti Platinum Pro Deep Fryer model EP65 but my heating element was damaged, I debating to sell parts or try to find a new heating element.
Posted on Dec 15, 2008
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
  • 10 Answers
SOURCE: Light pilot on Royal deep fryer. Pilot will not
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Posted on Feb 06, 2010
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Half way through heating pilot goes out
Sounds like your thermostat is bad, and/or high limit switch too. Check the thermostat first, and if you replace that, and it still does not work right, then the high limit next... Feel free to call Comstock Castle and ask for help directly through their parts/warranty dept. They should be happy to help you troubleshoot the problem.... Susan Restaurant Equipment Outlet, Cinc, OH
888-542-5959 www.restaurantequipmentinc.com
Aug 14, 2011 | Comstock-Castle 2941SF Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
What do I need to do to switch over from natural to LP gas?
You will need the following Castle part #s
17003A- Pilot head assy LP gas @ $49.
17006L-Convertible Press Regulator LP gas @$29.
Give Castle Stove a call @ 800-637-9188 to make sure that is all that you will need. They were the only two parts I found on there website (www.castlestove.con) under your model # for LP gas conversion. There might be a need for a conversion kit for the gas valve.
captrick
Jul 20, 2009 | Comstock-Castle 2616HG Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
Deep fryer burners will not lite
Does this fryer plug up to power of not?If it don't ,then thehi limit is out,need to reset it and try lightning it back.You will need to hold if for a minute.At this time if it don't stay lite,then replace the pilot thremcouplen.
Mar 13, 2009 | Vulcan EF4 Deep Fryer
Kitchen Appliances - Others Logo
20 people viewed this question
Top Comstock-Castle Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Comstock-Castle Kitchen Appliances - Other Expert? Answer questions, earn points and help others
