Bulbs are bad in my toshiba 27in lcd tv/dvd
The bulbs are bad where do i find new ones
  • 734 Answers
Try ebay?
Posted on Feb 12, 2012
jsinex2421
  • 62 Answers
SOURCE: dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Posted on Jan 10, 2009
  • 35 Answers
SOURCE: AKAI 27in lcd/dvd combo
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2721AD MLT166A REFURBISHED IN CHAINA
Thanks
GEORGE
Posted on Mar 17, 2009
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
  • 210 Answers
SOURCE: Startup of new Toshiba 32in LCD TV
press menu on remote and re-tune tv (look in the instruction book)
Posted on Nov 06, 2009
SOURCE: My Olevia 27in. LCD Television does not turn on
how do I set the stations, I have done everything that the manual says. I need the Auto station tuner....HELP this TV sucks.
A brand new RV, and can never watch the TV.....Most TV's you just turn on and It finds staions without all this ****......
Posted on May 08, 2010
Toshiba led lcd
There is no 'bulb' in LCD/LED tv.
The back light is LCD or LED only.
The shopJimmy also point to the bad inverter and/or LED driver
you should evaluate the cost of part + age of tv vs new
Apr 03, 2016 | Toshiba Televison & Video
Tip
Toshiba 23HLV84 Service Manual Download
Download Toshiba 23HLV84 LCD TV / DVD Service Manual
Have you misplaced your Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Follow this link (& click FREE) to download a pdf version of the Toshiba 23HLV84 LCD TV / DVD Combo Service Manual.
I hope that helps.
____________________________________
on May 03, 2010 | Televison & Video
Toshiba 56hm66 bulbs popping
may have got a bad new one or ballast board in set is bad. It powers the lamp.
Nov 29, 2012 | Toshiba 56HM66 56" Projection HDTV
Toshiba 47 inch lcd just developed a yellow smudge to one side of screen
does it take new bulbs? whenever i have this problem with my projectors it needs a new bulb, hope that helps
Aug 25, 2012 | Toshiba REGZA 46RV530U LCD TV
Toshiba tv/dvd junk
If as indicated here it is built into a set--and cleaning does not help--the optical pickup is likely bad(not sold as a part--only the whole DVD unit may be available).
Considering the cost of DVD units just buy a cheap external one and hook it to one of the rear inputs.
Apr 01, 2012 | Toshiba 26LV610U LCD TV
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
SAME PROBLEM WITH SAME SET! THIS IS A MANUFACTURES DEFECT. LAST YEAR I BOUGHT A SAMSUNG LCD TO HANG ON MY WALL IN BEDROOM TO REPLACE TOSHIBA. THIS TV COST ME $900 IN 2002, WHAT A WASTE OF MONEY! I HAD TWO...
make sure all other applances are ok not a line buffer are spike problem,maybe too high voltage coming for power company check with meter do you have a lot of bulbs going bad
Feb 22, 2009 | Toshiba 32AF41 32" TV
Thanks
GEORGE
Jan 27, 2009 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
