Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Philips 32pf5321d-37 i was washing it and a cracking sound then it went of no pic no sound help do i need a know one?????
  • 52 Answers
SOURCE: Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Posted on Aug 19, 2008
  • 197 Answers
SOURCE: 52PFL7422D/37 philips someone hit the screen and
buy a new tv panel bad cost about 2000.00
Posted on Jun 07, 2009
dsacco86
  • 1077 Answers
SOURCE: i have a philips 37 lcd tv will not turn on no
Right now the TV is in " Protection Mode " and the blinking light should be a trouble code.
Try leaving the TV unpluggeds for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 06, 2009
dsacco86
  • 1077 Answers
SOURCE: I have a philips 42PF9631D/37 and it will power on
Normally what happens with Philips TVs that does have a power supply problem, the TV detects a bad circuit board and goes into " Protection Mode ". The TV turns off and the red light starts blinking. With the TV having the green light ON, and no menu display coming up on the screen and no sound, I would believe the main mother board is the issue.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part or replacing the board. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part to solder in cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Posted on Jul 15, 2009
freetek
  • 5568 Answers
SOURCE: Philips 47PF9441D/37 Control board
Try this company' they reverse manufacture about every brand and do warranty their products:
Jimmy's Parts
BTW, the part number for the board should be ON the board. Since they never seem to stop making changes, it will probably be on a sticker or hand-stamped and will often have a 'Rev.' note with it. You can also do a search at that link for the control board by name with your model number.
Posted on Dec 09, 2009
37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
Jan 20, 2011 | Philips Televison & Video
My philips tv keeps losing the picture, still have the sound in the background but no pic, this has happened before and then went back to working fine, but yesterday turned on the tv, it worked for 5 secs...
Check if the tube lights up at the rear, the fillament must glow.If not check for badly soldered joints at the picture tube connection or the HT transformer.
Aug 15, 2010 | Philips Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Aug 27, 2009 | Philips 60PP9200D Television
Philips 32pfl5322d/37 went off and won't come back on
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look some bad caps (capacitors) on the power supply board. They will look bulged on thetop an may be a little leaky (brownish stain).
Then you can buy a new one at www.shopjimmy.com or ebay, you will need to use the brand and model number! Good luck, I hope this is helpful!!
Mar 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Please help with my Philips GoGear sa3245/37. i have no idea how to put pics or video on it
You have to use the program called Philips (Arcsoft) Media Converter. I would even get the updated version from Philips website.
-Tha Mp3 Doctor
Jan 16, 2009 | Philips GoGear SA3245/37 Digital Media...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
