Question about Electrolux Vacuums
My electrolux harmony vacuum suddenly won't turn on. Replaced the bag and filter. Still have no power. Did I blow a fuse?
4 Suggested Answers
  • 127 Answers
SOURCE: Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Posted on Jan 08, 2010
VacuumRepair
  • 438 Answers
SOURCE: model of BAg?
HI Your Exlectorlux uses Electrolux Style OX bags. Here's a few links back to our website to several different style of bags that will fit your Electrolux:
Genuine Electrolux Vacuum Cleaner Bags for Harmony Canisters
Generic Electrolux Style OX Vacuum Cleaner Bags for Harmony canisters
Hopefully this helped you! Please be sure to rate my repair helpful, or leave feedback if this was able to answer your questions.
Thanks,
Chris Jones
GoVacuum.com
Posted on May 03, 2010
mark24354
  • 776 Answers
SOURCE: Bought a used Electrolux canister
My first guess would be that the switch insidet the bag door is not pushed in (or missing).
The cardboard frame around the bag is supposed to push it in when the bag is properly positioned and the bag door is closed. The switch may be missing or loose.
The switch is there to make sure you don't run the vacuum without a bag.
good luck.
-Mark
Posted on May 28, 2011
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
I own a elecrolux 2100. the power light comes on but the vacuum wont start
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 17, 2011 | Electrolux Vacuums
I cannoot find bags to fit my Little Lux Model # L673BA
You can find those bags at
http://www.totalvac.com/850-12.html
Fits all Electrolux canisters/tanks made after 1954, (except Lux 9000, Guardian, Epic 8000, Renaissance, Harmony or Oxygen models) Generic 12 pack of Electrolux vacuum bags.
Mar 01, 2011 | Electrolux Little Lux Bagged Handheld...
Model of BAg?
Thanks,
Chris Jones
GoVacuum.com
May 02, 2010 | Electrolux Harmony Canister Vacuum -...
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
Can't get dustbag to fit
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
Apr 10, 2009 | Electrolux Harmony Canister Vacuum -...
Cover won't close
Try removing the bag and closing the cover. Unless that piece that holds the bag has gotten loose, there isn't anything that should prevent that cover from shutting, so it may just be the way the bag is sitting.
May 03, 2008 | Electrolux Harmony Canister Vacuum -...
Vacuums Logo
121 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
