Question about Air Tools & Compressors
My coleman powermate vp201 will not compress air? the fan works but the motor will not turn on? all wiring is where it should be. whats up?
2 Suggested Answers
SOURCE: What settings do I use for the VP201 compressor
Leave the compressor setting to the highest level.The other guage is to regulate the pressure output.For example if you need 40 PSI turn this regulator until this output is reached
Posted on Oct 08, 2009
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Sep 09, 2012 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate compressor wont start. It has always ran fine. Went out and the tank has no pressure. Everything looks Ok, but it wont start. Doesnt even make a sound. There is power at the plug in. ...
Two main things to check are the motor circuit breaker and pressure switch. Without knowing your model number I don't know exactly where to tell you to look but somewhere on the electric motor, or plastic housing if it's remotely mounted, there should be a reset switch/button. They are usually red or white, sometimes black. Push it in and see if the motor works. If the breaker keeps popping off there is something making the motor work too hard like bad bearings in the motor or pump, piston/cylinder issues, etc. To check the pressure switch, unplug the cord or turn off the circuit breaker. Remove the cover on the pressure switch and find the wires from the cord and motor. You can jump them on the switch (black to black & white to white) or disconnect them and connect the two black wires together and two white wires together. Turn on the power and if the motor turns on it's the switch if not it may be that your motor is burnt up inside. Don't let it continue to run like this because it will overfill the tank to dangerous levels without the pressure switch wired in.
Jan 28, 2012 | Coleman Powermate 27 Gallon Air Compressor
Need User Manual for Coleman Powermate VP201
http://www.powermate.com/productmanuals.php?cat_id=1
Scroll down to model VP0000201
Should be what you're looking for, manual is in .pdf format available for download.
Feb 11, 2011 | Vacuums
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
Manual for coleman vp201 air compressor
THE PSI RATING IS 70-100PSI. I WASN'T ABLE TO FIND THE SCFM AT THEIR WEBSITE. NO MANUALS AVAILABLE AS OF YET.
Jan 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Oct 08, 2009 | Coleman Air Tools & Compressors
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Oct 28, 2008 | Coleman Powermate 02 - Gallon Air...
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
