Question about E-Machines eMachines Desktop PC
Acoustic authority 2.1 speaker trouble on my emachinces W3653
The subwoofer works fine but only one satellite has sound i configured the system the best i know how to
  • 749 Answers
Check all your speaker wires for proper connection. while sound is running, run your fingers along the speaker wires and see if it cuts in and out, if it does , its a wiring issue.
Posted on Oct 24, 2008
CANT GET 5.1 SURROND SOUND TO WPORK
I'm not familiar with this system, but I can suggest the following:
Make sure the speaker jacks are plugged into the correct holes.
Make sure (in the control panel) that the sounds are correctly configured. If you tell the computer that there are only 2 speakers, then you'll have a problem. Be sure you subwoofer is powered up and connected correctly.
Most all problems are caused by "operator error." This usually results from an improper connection.
Apr 20, 2012 | E-Machines eMachines Desktop PC
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
Yamaha YST-MS50...how does it work ??
I have a YST-MS30 myself. Judging by Yamaha's site, the MS50 looks like it's built pretty much the same way. The subwoofer by itself is pretty useless. The power switch and volume controls are built into the right satellite speaker. There is a level control for the subwoofer, but overall system volume is controlled by the satellite speaker. You also need the power supply (15 volts, 1.2 amps for the MS30, but probably different ratings for the MS50 with its higher power).
Actually, it would be possible to open the subwoofer and puzzle out which pins in the connector you would need to jumper together to turn it on, and you might be able to find a suitable power supply. But it seems like more trouble than it's worth. Complete new system with comparable specs are around $100 from online vendors.
May 02, 2009 | Computers & Internet
Having trouble with IDT HD
You want to go to devixce manager and go to the driver properties. Then hit the button "roll back drivers" Cheers
Ben
Nov 29, 2008 | HP Computers & Internet
Sound card for emachines w3653
go to your sound card preffersants and change it to your set up .
Nov 19, 2008 | E-Machines eMachines Desktop PC
My Altec Lansing ADA745 speakers have stopped working. I probably downloaded some other software that overrode the Dell speaker installation. How do I reinstall the Altec Lansing ADA745 speakers?
The speakers are probably fine. What you probably need to do is to reinstall the sound drivers on your dell.
You need the model of your dell pc and go to the dell website and find download and install the sound drivers for your system.
The model of your pc will be needed if any more assistance is needed.
Sep 16, 2008 | Computers & Internet
No sound from my logitech z4 subwoofer
Is there sound coming from the 2 speakers?
Subwoofers are designed to only play bass, you shouldnt hear much acoustic sound coming from it at all.
The best way to test that is to play a song with a good amount of low bass, see if you hear it coming from the woofer, or can you feel the woofer vibrate?
If there is a hole in the side of the woofer box, when you are playing the song is there any air coming out of that hole to the bass line beat?
I dont know how you have your wiring set up, but if it still isnt working please check to make sure that you have the wiring plugged in properly.
If there is anything else I can do to help please let me know. I hope this fixes your problem.
May 13, 2008 | Computers & Internet
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
No sound from logitech x-230 subwoofer
Try the following steps:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Apr 17, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
96 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
