Question about Frigidaire Washing Machines
MODEL # GLTR1670A50
WASHER MAKING A LOAD NOISE WHEN EMPTYING WATER. CLOTHES DAMPER THAN USUAL WHEN REMOVING FROM WASHER
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
rickzilla
  • 706 Answers
SOURCE: Washer wont drain and spin.
There are a number of considerations cited in the user manual which you can get at this website http://www.frigidaire.com/support/ResultsPage.asp?strModel=ATF6000ES&User=
Drain hose is kinked or clogged,The house drain pipe is clogged or cannot handle the flow from the washer.. Your pump or the line entering it or exiting it is clogged..
Go to this website and download the parts document ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995464004.pdf Page 6 of this manual shows a filter (item 40) that protects the pump from debris.. That may be the root cause of your problem.. Hope this helps..
Posted on Aug 31, 2008
Buy an new one and trash this one
Posted on Sep 13, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
livewire874
  • 618 Answers
SOURCE: My Kenmore Elite He4t front load washer is making
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Posted on Feb 27, 2011
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
Whirpool front load washer model LHW0050PQ4 makes sputtering sound during spin cycle
Power plug off the wall first. Check out the pump which comes after the filter, something shd be clogging there; it shd move freely.
Remove back of machine to see if anything is touching the wheel belt or pulley.
Pl click helped, if helped.
Apr 09, 2013 | Whirlpool LHW0050PQ Front Load Washer
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Washer is making a noise and after the spin cycle clothes are still very wet
Number of things. The drain pump bearing could be making the noise, but if the water is out of the washer and the clothes are still very wet then you may have a transmission issue, including the brake or thrust bearing. The thrust bearing is more then likely the problem...part number...12500036. Not the easiest fix you might want to think about getting a tech to look at it...hope I've helped in anyway.
Apr 02, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Washer filled with water and then does nothing but make a clicking noise
If it's not spinning, the transmission is bad. If it's just not emptying the water, the pump is clogged or bad.
Unless you can replace the transmission yourself, it would be a better bargain to buy a new washer.
May 03, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Hotpoint WMA50 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
